help with line out converter for 2 amps
hey guys i have had a kenwood ddx7017 in my car for a while now, so no need to add inputs for amp ....long story short im gettin my car closer to stock to sell in the future, till then im gonna need a line out converter for my system, i understand the concept and where to get it, my question is do i need a special one if im running a 2 channel for my front components and a 2 channel for my sub ?
do i need two converters, or could i just tap one into the rear right speaker and one into the rear left speaker ? .. also can i adjust which one will have the high gain and which one the low ....links and recommendations would be great thanks guys
http://www.parts-express.com/pe/show...number=240-129
You could also use a 4-channel LOC, which would enable you to balance the system between the components & sub by using the HU's fader control;
http://www.crutchfield.com/p_142SLC4...4.html?tp=2001
You'd install that behind the head unit, tapping into all 4 of the HU's speaker outputs, then run two sets (or a single 4-ch) of RCA cables to the amps.
mischman
09-15-2015 03:38 PM
gqdabien
07-22-2015 10:30 PM
