How do u install cubby lights
i have a question, how do u change the cubby lights to a different color, im talking about the little space above the cigarette lighter
very carefully duh!... haha... there are a few ways... you can access it by the side sorta behind it... Or you can slide out the center console and do it that way... Oh wait, for some reason I tihnk you can get to it by pulling the waterfall out... brb to verify!
pull out the little plug in the footwell of the passenger side, gently pull out on the carpet, reach your hand in behind the waterfall area, gently grasp the base of the bulb/socket area and twist gently and pull it out.
i've never removed the waterfall to do it, so i can't say which way is easier.
When I did mine, I did it the way beedee described. Just make sure you first pull the round plastic tab which is holding the carpet to the center console out first before you reach around back or you might tear the carpet. It will give you some more flexability in sticking your arm back there too.
Originally Posted by daffy12
ha. i tried that. just when i had it in...the dumb little bulb fell out and i cudnt find it again. oh wellz i liked it better with a light in there...
think the mount/hole is like one of those 1/4 turn deals, and once it's out, it's some work to pull the bulb out... think I used some pliers... Its just so small it's tough to really get ahold of it...
SkillFreeJake
Scion tC 2G Aero & Exterior
07-27-2015 12:34 AM
CONCRETETC
02-09-2015 08:05 PM
TheRedBox
31
12-02-2003 04:53 PM
