how to hook up multiple amps?
I am going to run components and subs, each off their own amp. I don't know much about audio or electronics, but I've been taking it slow and doing it all myself, so far so good.
First bit of confusion though - I've run a power wire and fuse from the battery into the car, but now I'm confused about what to do for my second amp. Can I splice into the songle power line and run that into both amps? Do I hook up two power wires and fuses to the battery (this doesn't seem right because some people run a ton of amps)? Or do I need something else? I've seen people with things called distributor block, but I have no idea what they are. Is that what I need?
Thanks in advance.
Thanks in advance.
Power cable to a Distribution/Fuse Block and from there power to the other amps.
http://www.crutchfield.com/S-6FIzVIF...sp?g=715&avf=N
Re: how to hook up multiple amps?
There's more to it than just buying a distribution block, you need to ensure you've got the right size power wire from the battery to the block, and block to amps. The wire guage you need is dependent on the power draw of your amps and distance between amps & battery. If you'll state exactly what amps (brand, model and how many of each) you're using, I'm sure people here will inform you of the required wire size.
Also, there are lots of other decent distribution blocks available for less money than that page from Crutchfield offers. You can get something that functions just as good for only $4.45 by going here.
before you do anymore, read this!
https://www.scionlife.com/forums/vie...ee+audio+setup
on the ground wire, dont use a distro blk. Ground them seperate and away from each other. i used 4awg for power and ground. Make sure you sand down to take off the paint to get a good ground!
On the remote, you can do it like this. fom the HU run it to 1 amp, then from amp 1 run it to amp 2.
how did you run the power wire to get into the engine bay? Did you use the ruber boot above the pedals?
What type of wires are you using? I used ALL Stinger and i love it! Very clean and nice!
I'm running two eD NiNe.2 amps, one to power eDi-6000 comps and one to power 2 EU-700s.
I have power running from the battery into a fuse holder in the bay, then running behind the engine and into the passenger firewall. I'm using 8ga power wire.
Can I just get a 4ga -> 4 8ga distro block?
Originally Posted by Yanki01
^ explain
ummmm......ok?
i had my 2 grounds going through a distro block and that wasnt gonna work! I then had them about 5" away from each other and that didnt work. After all that i finally put them one on the drivers side and one on the pass side and that worked out fine?
That post does have usefull info! I believe it was explained well!
Sgtfluffy16
Regional - Northeast
07-28-2021 10:32 PM
