how to wire subs and amp?
OK. A friend gave me his sub/amp set up. However I dont think that it is wired up right. I could be wrong, most of the ohm, impedance, etc. is beyond me.
Here is the set up.
Speakers:
2 x Rockford Fosgate P210S4
Info:10" 4-ohm subwoofer
50-200 watts RMS
peak power handling: 400 watts
frequency response: 20-200 Hz
sensitivity: 85.8 dB
Amp:
Kenwood KAC-7201
Info:150 watts RMS x 2 at 4 ohms
230 watts x 2 at 2 ohms
460 watts RMS x 1 bridged output at 4 ohms
stereo or bridged mono output
4-ohm stable in bridged mode
Right now they are wired in stereo
Here is the set up.
Speakers:
50-200 watts RMS
Amp:
Kenwood KAC-7201
Originally Posted by combatsteve
if the subs are wired in stereo then they are correctly hooked up for that amp. Each sub is getting ~150watts rms.
there is a mono switch on the amp but I guess you have to run it bridged at 4ohms? Is it not stable at 2ohms? Are these speakers worth keeping and replacing the amp or is the amp worth keeping and replacing the subs?
EDIT: I think I found a problem. there is a high pass/off/low pass switch on the amp. it is set to off now so i am getting the whole bandwidth through my subs. when switched to low pass it automaticlly goes to mono. so i dont think this amp was meant to run 2 x 4-ohm subs. correct me if i am wrong.
here is the manual online: http://akamaipix.crutchfield.com/Man...113KAC7251.PDF
ok, so if the subs are rated for 200W RMS should i go for an amp that is 400W rms x1 @ 2 ohms for or should I go higher/lower? Would an amp that is rated for 600W rms X1 @2ohms be ok, or would I blow my subs?
Go with 600 or 800x1 2-ohm mono amp, you won't regret it.
great that helps a lot! Thanks
ok if i am going to get 1 sub for the amp listed above(460 watts RMS x 1 bridged output at 4 ohms) which should i get:
50-200W rms @ 4ohms SVC
100-500W rms @ 2ohms DVC
100-500W rms @ 4ohms DVC.
@Original Poster, disregard combatsteve. Ask anyone on the forums, more headroom on your amp is better. Rocketgyrl (our local audio expert) will come in here and tell you this if necessary.
and wire the coils in series which will present a 4 ohm load to the amp and you will get the most out of you amp.
FALSE. On an A/B amp, like he has, you will get more output from your amp if you present a 2 ohm load to the amp. Two 4ohm SVC subs wired in parallel to make a 2 ohm load will get the MOST out of his amp.
Here is my plan. All rockford fosgate. Take my two subs that I have now 2x P210S4(4ohm SVC 10"), and wire them in parallel to a P6001 amp(600W rms x1 @ 2ohm). Then get either a P312D2(500W 2 ohm DVC 12")or P2D212(200W 2 ohm DVC 12") and wire the coils in series to my existing amp(460W rms x1bridged @ 4ohms)
Thanks for the other advice though.
