i-KONA's reinvented cubby panel in stock! Great price!
CUBBY PANEL
SCION TC 2005 - 2008
What is it? It’s a panel that covers the cubby hole under the upper center counsel that can either be for look, hold switches, gauges, meters, etc. or simply for both. Created out of a set mold each cubby panel is perfect from side to side, thin, and durable. Made to fit up to 5 switches, one gauge and (2 switches optional space), and also cut to fit the scan gauge (2.8” x 1.5”) Perfect fit out of the box no alterations and or hardware needed to install I-KONA’s Cubby Panel., Just simply take off the lower and upper center counsel. Place the Cubby Panel in the groove that has the same shape. And place the upper and lower center back on. It will hold perfectly still and sturdy with out anything else.
The painted ones are guaranteed. Each panel has its top, bottom, and sides sanded down to assure theres no oils left from the mold making process.
PRICES
Standard - no holes, painted semi gloss black - $11.00
Standard Interior Color Matched - no holes, painted to match stock silver interior - $15.00
Standard Exterior Color Matched - no holes, painted to match any exterior or custom color w/ or w/ out clear - $18.00
Square cut 4.8” 1.5” for scan gauge + $4.00
Circle cut for any size gauge + $4.00
½” hole cut for switches + $1.00 ea
Anybody want a group buy?
PRICES
I need to check what kind of plastic it is again but no its not styrene. And for the scangauge 2 you don't need to use the tabs. I'm not sure how it holds exactly but from the guys who have the scangauge who have ordered cubby panels in the past all they say is just the cut is fine and they don't need extra hardware.
I thik this is the first time in SL history you see two guys with the same product on each others threads lol.
Chris I PMed you.
Chris I PMed you.
Originally Posted by FrostyTC
I think its kinda dumb unless it is used for gauges or something of that sort. Just to cover that hole... i don't understand the point?
Originally Posted by Macavely
That some nice work i-kona.. I think I might hit u up for one of them if you still have them in a few months.. really nice work .
CONCRETETC
02-09-2015 08:05 PM
TheTripleC
01-04-2015 06:46 PM
darkshadowofxdeath
12-03-2014 06:59 PM
