im bulding custom fiberglass sub boxes
#44
it all depends on the amp and the subs and everything that you buy. it's hard to just tell you what to get.
i'm not trying to be an ___ but you have the knowledge to build fiberglass boxes, but you don't know what to buy to put in them?
i have been doing car audio for a while and still haven't ventured into fiberglass.
#45
cadence txa-1000d
1kw at 1 ohm
nice damping factor, low THD, does rated power at 13.8v .
http://cgi.ebay.com/CADENCE-TXA-1000...QQcmdZViewItem
1kw at 1 ohm
#49
Originally Posted by koteman
that cadenece is expensive
the only bad thing i see with it is the size. it's 25" long. but other than that the specs look great and the price is good for that amount of power and features.
#51
so is crunch crap and dose that mean hifonics is to if they r same company
#52
both are heavily over-rated. i dont trust their quality at all. i wouldnt run it in my car.
for something with a warranty that does 1kw, that amp is a helluva deal for 200 bucks. im confused on one thing....did you mean 130+40 shipping on the pair of RSd's or each one? cause if each one, then we need to get you squared away with a better seller. you said each so thats why im confused. if its for the pair though, then thats fine.
#54
so im going to go with phoenix gold but should i use 10s or 12s 10 require .3-.5 cubic ft sealed and 12's require .78-1.2 cubic ft sealed
The thing you need to watch for is getting both volumes the same. I beleive the right side has more area so you may have to fill in some.
#55
Hifonics amps will typically do about 80% of what they are rated for. Thats not a dead right number but it is close to the average of what people see.
Also, don't buy crunch. Hifonics has better quality than Crunch.
#58
If the amp puts out more power at 1 ohm as opposed to 4 ohms then yes. And almost every amp does put out more power at 1 ohm than 4 ohms, there are a few exceptions.
If you take an amp that does 1k at 1 ohm and compare it to an amp that does 1k at 4 ohms. Then it really wont be louder or better sounding. I have heard arguments that it will sound better but I personally have no experience with that.
#59
well i bought the 2 10inch rds and the crunch 1000 watt amp at 1 ohm and a kicker 4 gauge install kit and a loc and it was about 390 with shipping and should be here on tuesday or wendsday
#60
to i put the speaker terminals in the back of my box today and then siliconed the crap out of it but i cant wait till tuseday so i can get my subs and the cut the speaker baffles and then stretch the fleece over the front of the box and fiberglass it and be done
