im bulding custom fiberglass sub boxes
Old 12-17-2007, 02:21 AM
  #61
socalsciontc's Avatar
When you get ready to do your rings and fleece I suggest trying to aim the subs slightly back if possible. When you get the front on be sure to dab into the fleece really good so it soaks all the way through. Even though I had several layers on the front, the largest area that was towards the front still flexed some on hard hits. I ended up going back on the inside and putting another layer on that section.
I can already tell from your glassing that its going to be air tight. Once I siliconed around my wire and installed my sub I could not even push in.
socalsciontc is offline
Old 12-17-2007, 03:43 AM
  #62
koteman's Avatar
y should i aim them to the back i was going to aim them to the front
koteman is offline
Old 12-17-2007, 03:58 AM
  #63
Just from my personal experience in my TC, the sound has always been best with the subs aiming back some. Right now they are firing directly up at the back glass, at the same angle of the glass. Sounds great but I can tilt the enclosure so they are firing more back and it gets better.
What would be ideal is a temporary small enclosure you could experiment with different angles. You might find that firing forward sounds best to you.
Old 12-17-2007, 04:03 AM
  #64
koteman's Avatar
i think im going to fire slightly up and towards oneanother
koteman is offline
Old 12-19-2007, 01:51 AM
  #65
koteman's Avatar
i got my subs in today and am install kit tommorrow and then amp will be here friday but while im waiting im doing an led swap for my gauge cluster and hvac so far it sucks they r tiny
koteman is offline
Old 12-19-2007, 02:51 AM
  #66
koteman's Avatar
so far my speedometer is blue and needle is orange still its cool gator colors
koteman is offline
Old 12-19-2007, 03:27 AM
  #67
jaxtcracer's Avatar
*CHOMP*
jaxtcracer is offline
Old 12-20-2007, 09:10 PM
  #68
koteman's Avatar
i unpacked my subs and they look awesome so im cutting the baffles and i already broke 2 speed saw bits and drained 2 batteries so i have to go get some more bits but i will up load some more pics latter
koteman is offline
Old 12-22-2007, 02:50 AM
  #69
koteman's Avatar
more photos of the last 2 days
speaker terminals
cutting the speaker baffels
test fitting
fleece stretched and started fiberglassing
on layer of glass
trimmed up
one layer of glass other side
2 layers of glass
[/img]
koteman is offline
Old 12-22-2007, 03:55 AM
  #70
nebster's Avatar
lol at those rings
haha ... i'll make sure to keep judgement until its finished but it looks good so far
nebster is offline
Old 12-22-2007, 12:22 PM
  #71
Nick06tC's Avatar
I would laigh at the rings, but I know exactly why they are like that. I tried usng a rotozip to do my rings and after 3 bits and crooked circles, Ipicked up the jig saw and it was 100% better. I dont think the rotozip style cutters are suppose to cut 3/4 mdf.
But all in all, you are coming along amazingly well!!!
Nick06tC is offline
Old 12-22-2007, 04:53 PM
  #72
koteman's Avatar
yeah i broke 3 bits
koteman is offline
Old 12-22-2007, 05:58 PM
  #73
koteman's Avatar
where should i run my power cable throught the fire wall pics would be nice
koteman is offline
Old 12-22-2007, 06:01 PM
  #74
Nick06tC's Avatar
The power wire runs through the fire wall. If you look under the dash above the pedlas and behind the steering shaft, you cannot miss it!!
If you really needs pics, lt me know and I will go take a few!!
Nick06tC is offline
Old 12-22-2007, 06:10 PM
  #75
koteman's Avatar
like where should i drill a hole or could i fit 4 auge wire throught the gromet that is already there with a bunch of wires in it
koteman is offline
Old 12-22-2007, 06:17 PM
  #76
Nick06tC's Avatar
The grommet is large and the wires run through thecenter of it.
Take a metal hanger and cut it. PUSH it through the side of the rubber grommet till you can see it in the engine bay, it will come out near the left front strut tower behind the throttle body. Now take the power wire and attach it to the end of the hanger with duct tape. Pull the hanger HARD through the rubber boot, It will creat its own water tight hole for the cable.
Nick06tC is offline
Old 12-23-2007, 06:51 AM
  #77
koteman's Avatar
im all done with building now just to finish the boxes and amp rack with some pain and nicer edges and lights i will do that tomorrow
koteman is offline
Old 12-23-2007, 07:05 AM
  #78
exige's Avatar
can i simply ask you one question? after all the advice you were given, considering all the SL members who took the time to write posts that would inform and help you....why did you go entirely against us on the amp? we, who have used crunch amps and know they're awful...we, who have much more experience in car audio than you (not meant in a derogatory way)..and we...who took our time to help you...why did you go against every bit of advice you were given about getting a ____ty amp? this is an honest question...and i would really like an answer to it. after all the time we took to help you, the least you can do is answer this question for me.
exige is offline
Old 12-23-2007, 08:46 AM
  #79
l3rl4n's Avatar
It's his project, his money, his final choice. He does not owe you an explanation for going against your opinion. I'm sure he appreciates your input, but don't blow a fuse if he doesn't abide by it.
l3rl4n is offline
Old 12-23-2007, 04:03 PM
  #80
koteman's Avatar
i was on a budget and it was only 130 with S&H and i spent 390 on everything
koteman is offline
Quick Reply: im bulding custom fiberglass sub boxes
