Installed: LMW LuxLink Remote Start *Video Uploaded*
Old 12-16-2006 | 04:22 PM
  #41
LMS's Avatar
LMS
Originally Posted by xIxAMxHOLLYWOODx
is there a neutral safety switch on the remote start? just incase you leave it in gear then try to start it and the car goes hopping across the parking lot and smacks into a light pole!
and furthermore, for manual tc's, can you completely trust your e-brake? especially after a long drive and the brakes are hot, then they contract after they cool? i know the e-brake is an inner-hub deal on the rear brake disc and that probably helps reduce the risk of the e-brake losing grip after heating up then cooling, but will it stop your car from rolling down a steep hill when you leave it in neutral?
Actually the remote starter has a safety feature were it will not start unless the car is set in neutral and you do a set of sequence before you turn off the car. "Pulling the e-brake 3 times." If you have any further question just contact me at the shop.
Doug
LMW/LMS
Old 12-16-2006 | 04:27 PM
  #42
LMS's Avatar
LMS
Originally Posted by xtonyC
Interested in group buy.
So does the remote start unit come with a security system too? Can it work with Scion's security system?
Yes the remote starter has an optional alarm upgrade as well. With the factory system it more of a passive alarm. If you tap the glass and rock the car it will not go off. With this upgraded unit it will set the factory alarm off. Tsystem is design to work with all factory sytem including your alarm. As for a group buy will have one early next year. Need to get inventory level in for it as well as a full complete installation instuction for you DIY.
Doug
LMS/LMW
Old 12-17-2006 | 09:44 AM
  #43
fearthisinc's Avatar
i have a few questions.. i am getting something like thsi for my girlfriend.. she has an automatic trans though.. the guy told me 275 installed and i just hit the lock button like 3 times or whatever.. my questions are 1. being it is an automatic does she have to do that 3 pull thing on the e-brake when she goes to get out of the vehicle? also i saw someone said that if you dont unlock the doors 3 seconds after remote starting you have to use the key to get int.. just wondering if there is any way around it.. i have never seen a remote start that would start the vehicle and then discable the fob.. thanks
Old 12-17-2006 | 09:23 PM
  #44
LMS's Avatar
LMS
As for pulling the e-brake 3X, no its only for manual because it a safety feature for the car. As for having 3sec to unlock the door you can change the setting from 3sec, 5sec, and 10sec. How the factory system works is that when the igintion turns the engine on the factory remote fob become disable after a set period of time. That is why you only have a max of 10sec to unlock the door.
Doug
LMW/LMS
Old 01-03-2007 | 07:51 AM
  #45
theunclesam's Avatar
Any update on this? I would be interested in purchasing this device. I'm in Chicago, so I would probably have to install myself.
Old 01-03-2007 | 08:08 AM
  #46
O5_TRD_tC's Avatar
oo nice autos dont have to do the 3x e-brake dealy :D. ill be interested.
Old 06-14-2007 | 11:11 AM
  #47
fl1p_tc's Avatar
i tried to look at the link but its not working...so ill ask here instead...is this alarm system soley just to be able to start the car or is it an alarm just like the alarm viper 791XV, etc... and can this come with an lcd pager thingy... hopefully it makes sense... so i kno if someone is tryin to break into my car/ thanks
Old 06-15-2007 | 01:18 AM
  #48
psycosoldier's Avatar
Default remote start with factory keyless enty key fob
Originally Posted by SupaWhite
Originally Posted by nebster
you're in SO cal and you need a remote start?!?!?!?
try being in iowa when its a solid 5 degrees out side. u know what i do. run outside in my boxers star the car and then run back up. i call it the manual start
But I'm in SoCal so I might get shot by a gangster.
i'm in socal too and getting an 08' tc in flint mica was pondering getting the remote start from where you got yours but do you have the factory scion security alarm that works with the stock keys too plus the remote start all in the same key? If so thats great and i would get it cuz like you i don't want any extra keys or remotes on keychain.HELP advice
Old 06-18-2007 | 11:46 PM
  #49
SupaWhite's Avatar
fl1p_tc ,
Nope. This does not come with a pager to notify you if someone is breaking into your car. It can also come with an alarm unit if you don't already have one.
psycosoldier,
The alarm and this remote start unit are all controlled by the stock key (it's main advantage).
Old 07-22-2007 | 07:34 PM
  #50
sindekat's Avatar
i was in until the 3 handbrakes
Old 07-23-2007 | 07:06 AM
  #51
SupaWhite's Avatar
I thought it may have been a hassle at first but it's no big deal really.
Just hold onto the handbrake button and lift gently 3 times. Let go on the 3rd pull and the brake will engage.
Old 07-23-2007 | 04:43 PM
  #52
sindekat's Avatar
but EVERYTIME? there has to be a way around it. maybe not with a factory keyfob but i know my boy put a remote start in his that didnt require that
Old 07-23-2007 | 04:51 PM
  #53
SupaWhite's Avatar
I think most of the other remote starts will not require you to pull the handbrake. The Luxlink system can be programmed so I would give them a call and ask about alternatives to pulling the brake. You can ask for Doug or Steve and they will answer any of your questions.
Old 07-23-2007 | 06:52 PM
  #54
O5_TRD_tC's Avatar
any word on the pricing?
Old 07-24-2007 | 02:05 AM
  #55
VeeDubbx's Avatar
thats pretty sweet
Old 07-25-2007 | 01:18 AM
  #56
Doug
LMW/LMS
i got a quote from you guys for my 08 a few weeks ago for an automatic but i didn't find out the start and shut off sequence i have do to i hope its not like a the manual withe the e-brake pumping thats tedious please explaing give me and other tc auto guys a quick break down of the linux system for auto transmission.
airmankevin1
02-14-2018 02:23 PM
mw1957
03-16-2015 07:00 PM
idriveanxa
03-08-2015 01:03 PM
757_BRDFLY
01-09-2015 01:29 PM
BV19869
12-11-2014 07:05 PM
