is300/celica gt-s gas pedal assembly rod, brake/clutch pads
Will swapping out and installing these components into our tC fit/work? I know mikochu did a swap with these parts into his xA, but what about the tC?
Well, our gas pedal assembly includes the potentiometer for the throttel by wire assembly, which I dont think the is300 had. So that part is most likely not going to work. Dont know about the rest of it. Why dod you want to change them?
I like the style of the pedals, and I realize now after reading mikochu's swap instructions that he only used the Gas pedal part which he used a punchpin to take out. And looking at the tC gas pedal assembly, I think this would work. I just might be crazy enough to order the parts and test it.
I just finished this mod. Total Pain in the **** to install and expensive too.
The Celica brake and clutch covers are flat on the backside and the actual tC pedals have a slight curve so it's a really tight fit, even more so than the OBX covers. The OBX covers I had have the curve molded in them.
The tC gas pedal rod is a little thicker than the Celica's so you have to Dremel the plastic on the back of the pedal to fit right. The tC gas pedal is plastic also, I always though it was rubber coated metal.
The Celica dead pedal is an aluminum plate screwed onto a plastic dead pedal. Unscrew it, Dremel the tC dead pedal, screw it on the newly Dremeled dead pedal.
I don't recommend this mod to anyone unless they really really want these pedals.
I had to order these from the dealership since I couldn't find any wrecked IS300s or Celicas with these pedals. So of course I paid way too much for this mod.
RY_TC07
07-18-2017 05:18 PM
