issue with DEI python 990
well i finnished my install today with my door lock triggers being the last wires soldered.
after i soldered into the plug in the kick pannel, i lost my auto window function on drivers side. i was driving at night and i noticed my window indicator light on the switch blinking. the switch works but no auto function for the 2nd stage of the rocker switch.
any ideas what it can be? something tells me a bad relay in the door. its late so i wont get to meter troubleshoot till tomorow but where should i start?
you have to reset the windows.
On the driver side switch, push the driver window switch down then hold it all the way up for about 2 secs then go to the pass side switch on pass side and do the same thing.
You may have to do your sunroof also. Just open your sunroof all the way and then close it and hold it for 2 secs.
That should work.
That should work.
That should work.
That should work.
Radiodude
32
06-14-2010 06:45 AM
