Just built my first ported box, and it sounds like a__s.
Here's the plan I followed:
I placed the sub on top of the box instead of on front like shown in the pic. I hooked up the sub, and turned it on, and I didn't even know that having that much port noise was possible. It sounds like a gust of wind every time the sub hits.
My sub is a 12" Fi Q. They recommend up to 2.5 cu ft ported at 32hz, with 12 to 16 sq in of port area per cu ft.
That box measured out to 2.6 cu ft, prior to sub displacement, tuned to 32hz.
I have no clue why there is so much port noise, I rounded off the sharp edges a little bit even with a sander. Anyone have any ideas on how to fix it?
ran the numbers on the measurements you gave
Im getting 3.4 cubes tuned to ~27hz.....
http://www.the12volt.com/caraudio/boxcalcs.asp
same height and depth but 28" wide would be 2.5 cubes before displacements
In order to tune that size port correctly, it would need to be drastically shorter, so short in fact that it would create a free air resonance box. Most ports following that design are for show. I suggest order ng 4x 4" dia port tubes, cut them at 10" lengths, and put them in the box facing upwards with the sub.
That sub has a very large excursion and displaces a large air volume. That port style is very turbulent.
Sooo those dimensions actually are correct.. Had it been a sealed box, it'd be 3.27 cu ft. But once you take out the volume of the port and wood inside the box, it'd be 2.68 cu ft.
The only thing wrong I notice, is that the port length isn't fully correct. With the length it is at, it is closer to 31hz tuning.
So all in all, after sub displacement, I will have a 2.52 cu ft box, tuned to 31hz, with 12.4 sq in of port area per cu ft of volume (with sub displacement out). It seems like everything worked out after all..
I'm gonna stick the sub in the box tomorrow, and as for the port, If i stick an angled piece of wood in the corner of the port, would that fix the port noise? or at least reduce the turbulence?
To reduce turbulence on that style of port, fillet or chamfer all of the edges (especially the bounding wall on the inside of the box)
The easiest way to do this would be to get some rounded wall molding and tack/glue it into the corners and that end piece.
Got the box built the correct way today. Sounds amazin. So much better sound out of it than my last 1.8 cu ft box. Just gotta retune the amp and carpet it. I will probably hit up the inside of the port too to reduce any little turbulence, but I can barely hear any port noise.
anti_virus347
05-28-2015 06:01 AM
anti_virus347
04-03-2015 05:17 PM
clickclickw00t
02-18-2015 08:57 PM
wiltonhall
01-28-2015 03:46 PM
