Kicker CompVR 05CVR102 with which Pioneer amp?
Hey guys..im not much of an audio head so sorry for the question.
But yeh which Pioneer amp
http://www.pioneerelectronics.com/pn...069933,00.html
Works best with the Kicker CompVR 05CVR102
http://www.crutchfield.com/S-UELTH3j...0&I=2065C10VR2
Thanks for the help. Flame away if you must.
If you're just going to power the Kicker CompVR 05CVR102, then your best choice is the Pioneer GM-7200M.
If you use the 7200M amp, you'll need to wire your voice coils in series for a 4-Ohm load. Wiring them in parallel for a 1-Ohm load isn't supported, per the amp's specs. No matter, I agree that amp would work well for you from a price:performance perspective. You'd get 250w from the 4-Ohm load, which is certainly adequate for that sub, and the amp would have plenty of reserve power to produce clean transient peaks.
Originally Posted by babyfac3pn01
^ soo ur telling me to go with the 7200m right?
don't buy pioneer amps...they are alright but if you want something good go with the Kicker KX300.1...I got that on my Kicker CompVr104 and it slams and plus the amps are more effiecent and last longer...go to www.onlinecarstereo.com you can get one for like 180
with one 10" cvr you would want to buy the dual 2 Ohm voice coil woofer and wire the coils in series to create a 4Ohm load on the amp... with the 10" woofer you should run about 600 watts RMS..... so with the amps you are looking at i would use the GM-D510M BUT BE SURE TO WIRE THE WOOFERS INTO A 4OHM LOAD OR THAT AMP WILL BLOW THE WOOFER...
prescottn
Scion tC 2G ICE & Interior
04-26-2016 02:14 AM
Hydryman
02-23-2016 04:35 PM
