L7 Kicker Sub
L7 Kicker Sub
So I'm running on a Scion 06 tC with ;
Boss 850 watt amp
L7 12" kicker.
It turns on and runs just fine.
But I'm having trouble with some static noises..
Could it possibly be the wiring behind the head unit or maybe just the fuse?..
Any suggestions or solutions would be helpful!
Boss 850 watt amp
L7 12" kicker.
What twitchion said.
Also you could check the power connection from the battery. But first make sure you have a very solid ground. Did you shave off the paint so that the ground is tightly against the metal frame of the car and not the paint?
yes, make sure the amp is properly grounded. make sure you do not run the interconnects with the power wire. usually what i would do is run the power wire along the driver side panel, and run the interconnects on the passenger side. this will help eliminate interference.
lex990
14
04-18-2005 11:44 PM
Gunnett
9
03-31-2005 02:57 AM
