LED/Cathode install in a tC?
Old 11-21-2006 | 08:49 PM
  #41
calvinlu85's Avatar
so, u used each cathodes for a transformer? and how abt the passenger side, and the back seats how can u run power to that cathodes to the fuse box ?
Old 11-21-2006 | 09:14 PM
  #42
Neothin's Avatar
alright here's how it's set up. bring power from the battery in through the grommet and then just make a couple of splices to bring power to each transformer. I have them ziptied up out of sight.
Old 11-21-2006 | 11:44 PM
  #43
lriicelboy's Avatar
can you take a picture of the location of the grommet?
Old 11-22-2006 | 12:39 AM
  #44
eLpReSiDeNtE's Avatar
tC squad
dats a good one.....maybe ethan hunt can do it for u......that tiny hole to the engine bay is barely visible i found it by mistake....lucky me
Old 11-22-2006 | 12:56 AM
  #45
lriicelboy's Avatar
lol... how about you show me then?? i dunno where the heck that thing is!
Old 11-22-2006 | 03:01 AM
  #46
tC squad
u have to lay down under ur driver side and look up above the fake pedal where u rest ur foot......have ur hood open and have a buddy flassh some light through the firewall around the same location where ur at under the driver side......u should see something .....that is about the bestttttt way i can explain it......maybe someone can explain it better
Old 11-22-2006 | 06:22 AM
  #47
pimptc's Avatar
can someone please answer my previous question?
***i currently have the factory illumination kit, is it possible to replace all the tubes and leds from the factory into cathode leds and cathode tubes and not rip out all the factory stuff (cutting of factory leds and putting cathode leds in place)***
if your not for sure could you direct me to someone who does, thanks a lot
Old 11-22-2006 | 07:07 AM
  #48
lriicelboy's Avatar
i dont think there are such things as "cathode leds". leds are leds and cathodes are cathodes. im not sure about the replacement thing though.. i just know that you might have to rewire the whole thing if you want to change it from the factory illumination.
Old 11-22-2006 | 07:44 AM
  #49
SquallLHeart's Avatar
what are cathode leds?
yeah.. whatever.. you can cut your stock stuff and still use the wiring... but why do it?
it'll be easier just to rewire everything up yourself... it'll save you from damaging your stock stuff.
Old 11-22-2006 | 04:31 PM
  #50
Neothin's Avatar
which you can try to sell and pay the cost of getting new things ;)
Old 11-27-2006 | 04:24 PM
  #51
calvinlu85's Avatar
the fuse box in the driver side, can i plug 4 cathode light in the fuse 10A of tail light?
Old 11-27-2006 | 05:27 PM
  #52
Neothin's Avatar
just go to autozone and get a mini add-a-circuit. it's made by littelfuse.
like 7 bucks and comes w/ mini fuses in the box.
add that to an open fuse slot.
or if your feeling ambitious, go to autozone again and get an auxilary fuse box and wire that under the dash. I now have all my auxilary power needs supplied by my secondary fuse box.
Old 11-28-2006 | 03:40 AM
  #53
calvinlu85's Avatar
hey Neothin, i havae a question for u, i want to connect all the wires from cathodes light and the wire from cup holer to a fuse. Does it have any effect to the fuse?
anyway, i don't know how to get power source for the cup holer, too.
Old 11-28-2006 | 04:26 AM
  #54
Neothin's Avatar
i dont completely understand what your asking....
yes you can run all of that off of 1 fuse.
and just run a wire to the cupholder area...
Old 11-29-2006 | 04:01 PM
  #55
Judes_Scion_tC's Avatar
ok im really lost. i want to hook up 2 led strips to a switch i got from autozone and to the fuse box under the stearing wheel (the cig light fuse) but i dont know what im doing at all. i wraped the wires around the fuse and stuck it back up in the box and the cig lighter worked but my leds wouldnt come on. (but i did have the car on and poked the wires up in the box to make sure they work and they do) each led had 2 wires.
so my question is... what wires goes where? which to the fuse box and which to the switch? also do i need a 3rd wire for somthing? my switch has 3 slots each labled.
*one says supply volts
*one says on acc
*the third says earth ground
so what whires go where?
Old 11-29-2006 | 04:16 PM
  #56
Neothin's Avatar
red wire from fuse to slot on switch that says "supply volts"
another red wire from the "acc" slot on the switch to the led strips
black wire from led strips goes to ground
black wire from "ground" slot on switch goes to ground
Old 11-29-2006 | 05:10 PM
  #57
ok thanx i get it now jus one more question. when hooking up the wire to the fuse box do you just wrap the wire around the fuse and push the fuse back in or is there another way?
Old 11-29-2006 | 05:14 PM
  #58
Neothin's Avatar
go to autozone and get an add-a-circuit.
looks like this-
http://www.42draftdesigns.com/images...-a-circuit.jpg
Old 11-29-2006 | 05:16 PM
  #59
sweet thanx 4 your help id be so lost lol ill get that and install them later and tell you how it went
Old 11-29-2006 | 05:18 PM
  #60
Neothin's Avatar
tell me? nah...
pictures
