LED MOD ON CLUSTER GUAGE NOW MY NEEDLES AREN'T READING....
CAN ANYONE HELP ME OUT WITH THIS I RECENTLY CHANGED OUT MY LEDS GUAGE CLUSTER. PROCESS TAKE OUT THE BEZEL REMOVE CLUSTER SCREWS NEEDLES...ETC WELL WHEN I WAS DONE PUTING ON THE LEDS I WANTED I PUT BACK ON THE NEEDLES AND THEY DON'T READ THE RIGHT SPEED NOR THE RPM OR THE GAS. I MARKED THEM DOWN ON A PIECE A PAPER .....
https://www.scionlife.com/forums/viewtopic.php?t=15164
6. PLEASE DO NOT TYPE IN ALL CAPS AS THIS IS CONSIDERED "YELLING."
Line up the needle pin with the housing and push down slightly, but not all the way in. Turn the needle counter-clockwise (for the gas gauge, turn the needle clockwise) until you feel it snag. That's the stop point. Pull the needle housing up and place it at your marking on the gauge to align the needle properly. Once it's all lined up push down the housing until its almost flush with the gauge. (Don't push too hard or the housing will be too close to the face of the gauge and will end up rubbing against it and the needle won't respond as quickly as usual. Also try to push the housing in as straight as possible or the housing will spiral around the pin and you'll not be perfectly on the stop point.)
Opr8r
18
10-30-2003 05:28 PM
