New AVH-P4000DVD, Anyone Installed It?
I've been looking for a DVD player for my dash, one without GPS (I already have a GPS unit and a phone with same service on it). Been looking around for relatively inexpensive dual-din unit to install and came across this at my Best Buy.
Anyone seen this installed? I'm curious if you can keep the waterfall cover that comes with the center console and have this unit installed? If it comes down to it, I suppose it'll look great flush with the dash, but thats a last resort.
Any reviews out there? I know its a new unit so...
Pioneer AVH-P4000DVD
BBY and Crutchfield have em on their sites now
I'm going to get this one when I get the money. Just need $378. Wanted to get one with GPS, but don't want to spend more than $600 and I don't want the AVIC D-3...everyone has them. The Crutchfield reviews are the only I've seen so far.
Originally Posted by etoomey3
interested too, want to get one, went to Best Buy but they didn't have the install kit???? LOSERS
and YES you can keep the stock waterfall cover if you get the avh4000 and install it properly.
On Mine - after install I had a one finger gap on each side but then bought this http://www.sonicelectronix.com/item_...a+95-8202.html which filled the gaps out...
As for the door closing, It kept hitting the volume **** on the way down, so I took of the water fall and "dremmeled" out a section of the back of the door (that you can not see - and it now fits perfectly!
I will be posting pictures later - keep watching for it
First things first - I installed my 4000 this weekend - I wanted to be able to have movies play while driving so I wired a toggle switch to the parking brake wire and then ground it. This allows me to flip a switch for the system to think the car is in park when in reality it is not. originally I tried tieing in the parking brake wire with the ground wires on the harness, but that does not work for this particular unit (some models do, but not the 4000) I mounted to switch in the underside of the cubby hole and is out of sight completely unless u look at it from under. I also wanted the door to be able to close, but it hit the volume ****, so I used a dremel tool to cut out a small section where it was hitting, and it is not even noticeable (unless obviously you take the waterfall out and look at it from behind) I also ran my iPod cable down and through the center into the empty cut out in the center console. Lastly, the stock (mounting) bracket was able to fit perfectly into the 4000, without any modification whatsoever - I bought the plastic black side pieces (http://www.sonicelectronix.com/item_...a+95-8202.html) for the side and those fit very well, the only thing you have to do is cut off one small section of it so it mounts flat and doesn't crack (it shows you how in the supplied instruction manual)
P.S. My HVAC unit has no buttons on it right now, because I am in process of an LED swap...
Here are some pictures:
Ground Location Used for Parking Brake Switch
Cubby Hole - You Can Not See The Switch
Cubby Hole - Switch Up Close
iPod In Console
Hole Cut for Volume **** - Up Close
Up Close - Can Not See Hole When Open + Dash Kit on Side
Door Closing
Door Completely Closed as Stock
PacMan/Galaxian/DigDug (Ran into Rear RCA Input)
UpClose Games Turned On
.....Any questions or pictures of other things anyone needs, please feel free to ask - I'm more than willing to help out[/b]
iPod In Console
Door Closing
Originally Posted by FLEA
Video quality when playing DVD's?
TheRedBox
31
12-02-2003 04:53 PM
