New Battery, loss of voltage overnight
Had to get a new battery since the stock battery was failing the load test. The new battery when new was 12.6volts and yes it did pass the load test.
But this is odd. When the battery has sat overnight and I read the voltage it's 12.44volts. I've checked the alternator and it's charging correctly. What would cause a battery to lose 0.14volts overnight? Is the battery bad? I was wondering if it was that emissions pump that runs for 5 minutes after 5 hours of sitting.
Someone help me out here, I really need the help.. thanks
There's always gonna be voltage drain on a battery. Your factory keyless entry system is always using power, not more than a few mA though. Also if you have an aftermarket alarm this will also cause a drain on the battery.. not enough to kill it overnight though. Any aftermarket electronic equipment installed?
Nope no aftermarket equipment, just stock, but I found the drain.. thanks again.
knuckleheadjcz
12-24-2015 09:07 AM
