Pioneer AVIC-D3 Roll Call.
#165
you dont actually have to drive around the block, my bypass kill switch goes off right away when i flip the switch to off and the car is on. i think the sensor is just on the parking brake lead, so no need to drive around the block
#166
Good point, I wasnt sure tho. With the bypass, do you get any of the ebrake warnings when you turn the system on?
If not, I DO. So that means I gues I can just keep turning on and off till I have a good conection.
#167
my best guess is that you didnt ground the ebrake correctly. cause when i turn my own it just says "driving with nav yada yada yada" check your connection settings and it should say the status of your ebrake ground.
#172
put your pictures you want in a folder called "pictures" then burn that file on a cd in its root ( cd drive/pictures) and that should work. the file has to be at least 1.8megs in size for the d3 to be able to read it.
#175
Mine was plug and play, but when I plugged it in, I accidently pulled out the mute wire. When I went to put it back it, i was putting it backwards. When looking at the pin, it looks like it SHOULD go one way, but it goes the opposite. I finally had time today to sit down and take my time. Works like a charm.
#177
Avic-d3? for 2007tc
Just trying to find out if you can still use the ipod hookup in the arm rest with the d3 or is it disabled just as the steering wheel controls are? I've seen the adapter for the SW controls but is there one for continuous use with the ipod in the arm rest?
#178
No the armrest will not work anymore, but you do have a jack on the front of the D3. And if you do decide to do the steering wheel controls dont forget about the 150 ohm resistor.
#179
pureXTC... i got bored at work and made it in photoshop
jbgame13... you cant use the OEM ipod adapter, however you can still run the d3 ipod adapter up to the arm rest. and for the steering remote its the PAC-SWI PS unit.
