PLEASE HELP :( ECLIPSE AVN6610
for some reason the indash started to act up....i unpluged the main power wire from the headunit because i was installing the bluetooth for the indash, and when i plug it back in, i get a msg saying ESN, PLEASE INSTERT DISC....my nav disc is in the player....i tried everything already....i tried to put the map disc in the map drive....didnt work....tried putting the map disc in the cd/dvd drive....didnt work....tried unplugging the power harness again for it to restore its settings....still didnt work...and nothing is accessable no rear view cam, no music, no nav, no nothing.....PLEASE HELP TO TELL ME WHAT I NEED TO DO, i've been looking everywhere and i cant find anything
Did you buy the unit used?
If so the original owner may have used an ESN disc to lock the unit.
Eclipse radios have this so if they are stolen they will not work. Anytime the power is cut off from the unit and then repowered the unit will sk for this disc.
If you are the original owner and dont remember using the ESN or dont have the disc you may have to send it in to Eclipse and have it reset
If it were me, I'll be honest... this is what I would do. It would take a while, but, it may just be worth it. I would go through each and everey cd I have in my cd case just to be sure I didn't accidently activate the feature with a different cd... I know this may be unrealistic if you have 1000+ cd's, but I guess it depends on how much you need this. If you didn't register with Eclipse, I doubt they're going to unlock it without a reciept, along with serial number verification on the reciept. Hopefully you have all of this. Good luck getting it unlocked!
Simez2003
04-15-2005 07:13 PM
rbloedow
06-24-2004 11:18 PM
