POWER WINDOWS HELP!!
ok... well i got a problem
on the drivers side the windows work but they dont automatically go down when i push the button down all the way. vice versa with goin uping. then i cant even move the passanger window at the drivers side for some reason. only the passanger can move their own window. so i dont know whats going on ? can any1 help me
Re: POWER WINDOWS HELP!!
Not to worry - here comes the obligatory PLEASE SEARCH FIRST slap though...
Roll the windows down all the way.
Now, roll them half-way up.
Now, roll them the whole way up and keep holding the up button for 1-3 secs.
They should now work.
Scott
PS - here's the tC FAQ site: Click Me for FAQ
Scott
if you had any stereo speaker work done which requires the removal of the door panel, they might have not fully connected the harness. If you have had no audio work done or anything requiring the removal of the door panel, I suggest you take it to the dealer. Maybe the window master switch is bad or faulty, another posibility could be that the connector could have come loose.
Also I am not sure what you meant by the "windows not going down when the button is pushed all the way down." The auto down only work on the driverside window not on all of them. Only recently have manufactures started making all the windows auto down from the window master switch.
If you just meant the driverside window, it's a problem but if the rest of the windows go down only when pressed this is normal.
shoot sorry bro didn't know it was a TC. . .should read more. . .ha ha ha
ok so when i do it for the passanger window... it will fix it so i can open it and close it on the drivers side?
Ok...... This is the 1,354,434,343 time this has been asked.... it happens every time you reset your ECU....
follow the instructions for both windows and your sunroof and you'll be good to go....
As for the other answers.... DO NOT go to your dealer for this.
daniinpitt
04-04-2015 08:07 PM
