PS2 Slimline
PS2 Slimline
hey everybody. i want to put my slimline ps2 in my glovebox. my question is, is there a car power cable for it? im mean it already runs off dc power so i dont want to put a ac/dc power transformer.
slimline running off of DC? nah..
you need an inverter, and then you can just plug it in. you can mount the inverter to the little panel under the glove box. Thats where mine was mounted before I moved it under the passenger seat (where it later blew up for some reason and i threw it off the top floor of a garage at school)
just buy a converter it hooks to your lighter or direct to your battery so its hidden. no wire cutting anything. i use to have one hooked in my caddy, i also hooked it to my alpine head unit to get my sound thru the car spakers
how much does one of these inverters cost? I'm considering putting one of the slim ps2's in my car as well. (I would rather an xbox, but a slim ps2 would just fit so much easier then anything else)
or you could just power it directly off of 12 volt, inverterless.
Oznium shows you how:
http://www.oznium.com/articles/12
good article jetlounge, thanks. Anyone know how much voltage a ps1 needs?
Edit, Nm, just looked at my ps1, it needs 7.5
so, the mouser voltage regulator says it's adjustable, so.. does that mean you can adjust it to let out 7.5 v if you want? or 8.5 for ps2.. or whatever xbox needs?
i've never seen a ps2. i am assuming you have a power brick that converts the power for the unit? (i'm an xbox fan)
anyway, i would assume you could cut the cable plug end off of that power brick and solder it to your + & - leads from that conversion kit. Place your whole kit inside a little radio shack project box, or just open up you power brick, remove the PSU board and replace with yours.
oznium has a forum with some knowledgable posters, you can probably get some concrete answers there.
TheDave1022
Scion tC 1G ICE & Interior
177
09-28-2008 06:31 AM
magnetic
08-09-2008 01:20 AM
justmyluck
06-30-2006 12:34 PM
OMAC
03-15-2005 05:57 AM
