Push Button Install Help!!!
Ok, i have a 2006 scion tC. I bought a Pilot PL-SW50R Push Button Starter Switch.
I need help because i DO NOT get the wiring at all....
Ill post pics in the next post to show you what i dont get.
12volt wire is red and a white wire
Starter wire is black
second starter wire green
i have mine in my cig lighter location by the shifter
you must cut the starter wire use a volt meter to check it and once you cut it you shouldnt be able to hear the starter crank
I got a new problem though... My friend told me a neutral safety bypass is cutting the wires that go to the neatral safety butting right under the clutch pedal, and connecting them together.... It works to get the car started but the CEL comes on and i have like 10 codes for pretty much all the sensors in the engine, and now my DOME lights wont turn on and the one in the back on the left in the trunk. The way i start my car now is to connect the two wires together, start my car, then disconnect them and its ridiculous.... Any suggestions?
TheRedBox
31
12-02-2003 05:53 PM
