remove the grocery hooks
Old 09-12-2007 | 06:20 AM
theblue's Avatar
Default remove the grocery hooks
can someone give me some tips on removing the grocery hooks? According to the gutting guide, I need to turn them 90 degrees clockwise and pull it out, but no matter how hard I pull, the hooks wont come out. how hard should I be pulling? Is it even necessary to remove the grocery hooks to remove this panel? my fingers are hurting like crazy trying to get these pieces out...
Old 09-12-2007 | 06:21 AM
ADRdesignCo's Avatar
which panel?
Old 09-12-2007 | 06:25 AM
Hyghgynx's Avatar
You need a screwdriver to push in one of the tabs. (You'll know which one it is because it moves rather freely once you push it in.) After turning 90 degrees, push in the tab with the screwdriver and it should 'unlock' itself from the panel.
Old 09-12-2007 | 06:33 AM
markritch's Avatar
yea push the bottom with a flat head and twist ....very easy
Old 09-12-2007 | 06:35 AM
theblue's Avatar
oh so I need to push in the tab even after its been turned 90 degrees to pull it out? that would make sense i guess. I'll try that tomorrow.
Old 09-13-2007 | 04:34 AM
theblue's Avatar
ahh i just tried it, and I swear its not coming out. Its all rotated 90degrees clockwise, and I push the pin and attempt to pull it out at the same time (even tried with pliers) and no matter how hard I pull it won't come out.
if theres anyone in the los angeles area that can help out, please PM me...this is so sad...
Old 09-13-2007 | 04:36 AM
RodC's Avatar
Just curious - why do you want to remove the hooks?
Old 09-13-2007 | 04:40 AM
theblue's Avatar
im putting edead on my car right now, already finished the driverside door and the trunk. I want to the rear wheel wells which are right behind that panel. apparently the grocery hooks hold this panel in... i don't understand why but its in mandos' gutting guide.
https://www.scionlife.com/forums/viewtopic.php?t=60981
edit:
now that i think about it, how the hell do the grocery hooks hold this part?
Old 09-13-2007 | 04:49 AM
Hyghgynx's Avatar
Depending on which end the tab (that you push in) is located;
Tab on top---turn clockwise.
Tab on bottom---turn counter clockwise.
The hole where it 'unlocks' from the panel should be at 9'o clock on the passenger side and 3'o clock on the driver side. (I'm pretty sure about this.)
Side note; usually you want to remove these to replace the stock speakers, redo the middle part of the panels with suede/vinyl, install an amp, etc. Pretty much whatever you can think of to use in a limited space.
Edit; they are also held in with those white clips that are throughout the car. :D
Old 10-02-2009 | 08:37 PM
breimann's Avatar
Not to revive an old thread...... BUT....
A question about these hooks:
I know how to take them out no problem, but I'm having difficult installing them! As a result the plastic is starting to get chewed up. I'm going to attempt installing them again over the weekend so my question may be a moot point. Is there a technique or a way they need to be lined up prior to installing?
The annoying thing is, I did all of this in the spring and put them BACK in no problem.
Old 10-02-2009 | 08:43 PM
beandip007's Avatar
SEARCH!!!....
Nah just kidding, a good place to help you is this section of the forum...
https://www.scionlife.com/forums/sho...ght=gutting+tc
Hope this helps you.
Old 10-03-2009 | 01:05 AM
DJ08tC's Avatar
Yea they can be annoying to put back in. Just keep messing with them, mine got kind of chewed up too but they still work.
GUAHAN671
05-20-2015 06:22 AM
stayintrucha
Scion tC 2G Aero & Exterior
05-16-2015 06:32 PM
SpaceCaptain
05-11-2015 07:24 PM
MadSciontist_xB
05-10-2015 07:28 PM
billzor
Scion tC 2G ICE & Interior
01-17-2015 01:38 PM
