Scion tC Speakers
Old 04-17-2009 | 04:52 AM
Steve1991's Avatar
Default Scion tC Speakers
How many Watts does the stock tweeters in an 05 Scion tC have?
Old 04-17-2009 | 05:03 AM
ahatch133's Avatar
not many? lol
Old 04-17-2009 | 05:04 AM
Pilmo's Avatar
dont they come sstock with a small sub in the trunk
Old 04-17-2009 | 05:11 AM
jobunaga's Avatar
not the 05. and what the hell does a stock sub have to do with how many watts the tweeter has?
IRTOP
you can calcluate that each speaker does 40 watts max, which equates to about 13-15 watts rms.
Old 04-17-2009 | 05:18 AM
ahatch133's Avatar
lol fail
they dont have much, why though? that should be a factor to the question or are u just being a curious george lol
Old 04-17-2009 | 05:40 AM
Hyghgynx's Avatar
Just buy new component speakers for the fronts and rock on!
Old 04-17-2009 | 05:55 AM
ahatch133's Avatar
^thats all u need. heck u dont even need to amp them.
Old 04-17-2009 | 05:27 PM
09tC_CB7's Avatar
What are you trying to do? If you are just replacing your head unit, you are fine. If you are doing that and using an amp, you may have an issue.
Old 04-17-2009 | 05:29 PM
ahatch133's Avatar
and youll know if u blow em. most of your "sound" lyrics and whatnot are coming from those then ur bass and stuff is coming from your component's and tweeters are hard to insall in the tc if im not mistaken.
Old 04-17-2009 | 05:43 PM
09tC_CB7's Avatar
It isn't that hard. There is already a location for them which means you are not cutting up your car to mount them. Someone did a write up on them here somewhere. They bought new tweeters, took the mounts off the OEM ones and attached them to the new tweeters. Other people just hot glued the new tweeters in the door where the OEM ones were.
Old 04-17-2009 | 05:51 PM
DJ08tC's Avatar
That or you could mount them in the kick panel because tweeters from components are often pretty harsh in the stock tweeter location.
Old 04-17-2009 | 07:31 PM
nodsetse's Avatar
Default Re: Scion tC Speakers
Originally Posted by Steve1991
how many watts does the stock tweeters in an 05 Scion tC have?
1. Why do you ask?
2. What did you really mean to ask? (your question as stated makes no sense)
3. They have as many watts as you feed them, without amplification they have no watts.
4. Do you want to know how many watts they'll handle?
5. What is the attenuation rate of the high-pass filter you'll be using (stock cap. only?)
6. At what frequency does the filter take effect? (-3dB at ?Hz)
7. What is the content of the signal being fed to them? (tones & their duration)
All the above matters, regardless of specifications. There are tweeters rated at 10w RMS / 20w Max that can easily handle 100w peaks for short periods when filtered fairly high with a steep slope.
The tC's stock tweeters could be destroyed with as little as 2 watts, or survive many years with 100 watts, depending on how they're used.
Erickdimas7
Scion tC 2G ICE & Interior
01-16-2015 04:41 AM
lunchbx05
12-29-2014 08:53 PM
rancur3p1c
Scion tC 1G ICE & Interior
12-21-2014 10:23 PM
linlow
12-14-2014 01:56 AM
cwong1001
12-03-2014 04:30 AM
