SS cage risers
SS cage risers
So basically I was installing my Doc Isotope short shifter w/ cage risers and 1 of the risers fell into this little hole underneath the cage........ Can't get that shyt out. Anyways I 'm probably going to email doc about reordering that 1 piece. Once I get it you guys think I can just do the install by just take out the panel which holds the shift boot, and from there just unscrew the bolts and add the risers? Or would I have to take apart the whole center console and cup holders to do it? If I can't would I have to order another washer to put on the rod again? Thanks.
https://www.scionlife.com/tech/image...ift_tc/004.jpg
(Took this from the DIY) But jsut wodnerinf If I could add the risers by just taking off this part, isntead of the whole thing.
i think youd be fine with just taking off the piece with the shift boot alone. but it only takes a minute to take off the whole thing, so why not? just to make sure you get everything in good, and avoid dropping another bushing into the black hole
Originally Posted by SquallLHeart
gripper snake thingy tool..?
i used a screwdriver to drg it closer and bit my lip and did my best to pin it against the housing and slide it up with my finger
BlingSlade
09-05-2015 08:52 AM
TurboToyotas
46
11-02-2007 02:32 AM
jay_jay_n
30
10-03-2006 06:02 PM
