Stock Deck Line Output Converter For Stock Deck! HELP!
I have a stock deck 2008. I have wring, amp, subs, evverything.
I have already searched BTW.
I have a Line Out Converter with 6 wires, 2 White, 2 Grey, 2 Brown, with 2 RCA on the other side. Can someone help me wire this together? This is very confusing for me, im not to familiar with stock wiring of deck and speakers. Thanks guys. quick help if possible im working now Detail description please
cap off the brown you do not need them, they are used as a ground. The white would be the left side of the channel and the grey would be the right. I prefer to hook them up to the rear so when you fade them front and back the sub will fade with the rear.
Take your white wire and connect it to the brown wire on the back of the radio. Take white/black and connect it to yellow. This will be the left rear speaker. Take your grey wire and connect it to red and then take your grey/black and connect it to white.
If you have more questions please let me know.
Are there any lights on the amp that will turn on? Protect light, a light that lets you know its on... anything? The only thing I can recommend to you without knowing more is to check your fuse not only on the power wire but on the amp itself. Should be a 30 amp fuse (on most amps). If you have a volt meter measure out the remote turn on wire when you have accessory power and the power wire. If you do not have power there then thats your problem... let me know what you find out.
lunchbx05
12-11-2014 06:13 PM
darkshadowofxdeath
12-03-2014 06:59 PM
