Stock shift knob's threads too tall for short shifter?
Stock shift ****'s threads too tall for short shifter?
I have TWM Stage 2 short shifter and I can't get the stock **** to screw all the way down. It runs into the boot clip which prevents it from going down all the way. Is this normal? I'm going to get an aftermarket ****, probably a Momo, but want to make sure I Won't have this problem with it.
So you mean the bottom of the aftermarket shift ***** are higher than stock? That's what I'm assuming, just want to be sure. I had to remove the white clip inside the boot so it would sit lower just to screw the stock **** on all the way.
Yes, it came from TWM, it's the Stage 2 so it's pretty short. Here is how it looks with the white circular clip removed so the boot sits as low as possible. I'd like to pull it up a bit once I get a new ****.
NonStopTuning
06-29-2015 07:42 PM
