Sub recommendations
Sub recommendations
Hi all, I have been reading posts around here for a while, and this is my first post so please be kind...
I am loking for a recommendation for a subwoofer. I am going to be building a box similar to this one https://www.scionlife.com/forums/viewtopic.php?t=158758 and i was looking for a sub that would fit, and here is my list that I have narrowed it down to.
JL 10W1v2-4
Rockford P1S410
Rockford P3SD410
MTX US-XT10
Pioneer TS-SW1041D
kicker comp10
kicker compvt10
and here are some more detailed specs on all of them
I only have two limits if some one wants to suggest one i missed, and that is that it needs to be under 5.5" deep, and I am only looking at 10" subs
JL 10W1v2-4
Rockford P1S410
Rockford P3SD410
MTX US-XT10
Pioneer TS-SW1041D
kicker comp10
kicker compvt10
I was thinking about getting two 8inch ED subs - which amp should power them? also - its stating D2 and D4 coils when order - which would I want if I was going to run two subs?
I was thinking about putting them in a sealed ED box.
the only sub that would fit is the Pioneer TS-SW1041D and even then its a rip off. just buy the loaded sq 10 box from elemental.
http://www.edesignaudio.com/edv2/pro...roducts_id=465
Oh ok - I went there to begin w/ but I just didnt know. When I was in the audio game 6-8years ago we had a positive and negative terminal ....hehe. I dont know if i want 4ohms or 2ohms - also i dont know if i want/need the NINe.2 or the NINe.2X
With two 9kv.2s, the only 8" sub offered by ED, you'll want the Nine.2. The Nine.2x is what i'm using for my 130.v2, and I see up to 70 volts AC coming out of it when I crank the gain all the way up. 600 watts is 49, so you do the math. In conclusion, the Nine.2x is overkill for your situation.
That was a D2 sub bridged. You'll bridge two D4 9kv.2s wired parallel on a Nine.2 to extract 400 watts out of it (200 each).
200 x 2 @ 4ohm
The Nine.2 is putting out:
1 x 400 @ 4Ohm, 2 x 150 @ 2Ohm
2 x 100 @ 4Ohm
