Tach Wire
Originally Posted by Matt_Burgess
Would this tach wire work for a msd window switch ?
http://msdignition.com/forum/index.php
did anyone else order a shift light and its like 6" long and wont lay on the steering column without hitting the wheel when u turn....any other location ideas? I was thinking of mounting to right knee plastic thing, because its on an angle and i will still see the flashing light....
Based on wat ive read from the PDF intructions the tach wire can easily connected at the gauges instead of pulling out the OBD II connector and laying on ur back trying to solder when u can just take out one screw above the gauges and pop out the connector and tap into the PIN 26....please let me know if this sounds right, il try it anyway later today after work if i get no reply....with pics lol!
No way it took me under 5 minutes to install, check it out....i did a custom mounting which worked out great, just thought of it on the spot (im the first),i just took off the bracket that comes built in and ran the wires through the vent opening slot and made a tight fit so it didnt move around, so much easier because the wires only were 8 inches long so the connector was right next to it (no patch wires)
how many wires did you have? because i know most have 5(3 regular, 2 closed loop), you have to cut the 2 looped ones for your 4 cylinder, and then 1 accessory(gauge cluster), 1 ground(bare metal), 1 tach wire(to gauge cluster)
pjl52
08-13-2015 02:38 PM
domincnTC
08-04-2015 01:47 PM
Wrencher
07-29-2015 01:38 PM
semlin
07-29-2015 02:07 AM
