trouble removing ashtray bulb
Old 01-19-2013 | 05:34 PM
minhpho's Avatar
Default trouble removing ashtray bulb
so im having difficulty removing the ashtray bulb to replace it because its so small and theres not a lot of space to maneuver around. any tips on how to remove it? i tried tweezers to grab it but no luck so far.
Old 01-19-2013 | 07:02 PM
stenger's Avatar
Did you try taking the waterfall out? (radio/hvac panel)
Old 01-19-2013 | 07:58 PM
minhpho's Avatar
yeah i took that out to try to give my hand some more space but no dice. the bulb is just a pain in the butt
Old 01-31-2013 | 02:56 AM
minhpho's Avatar
bump
Old 01-31-2013 | 06:23 PM
HKSpeed's Avatar
are you referring to the bulb in the storage area under the A/C and heater controls? if yes, you can reach it from the passenger side area by pulling back the plastic and carpet. you can pull the light assembly back from there to swap the bulb. Took me less than a minute.
Old 01-31-2013 | 06:35 PM
minhpho's Avatar
Pulling which carpet and plastic? And do you mean pulling the entire light assembly, socket and cable and all?
Old 01-31-2013 | 06:56 PM
rs70936's Avatar
yes
Old 02-01-2013 | 04:02 AM
rkuemmer's Avatar
Easiest way is to pull the waterfall off and pull it out that way good luck
Old 02-01-2013 | 04:01 PM
minhpho's Avatar
Originally Posted by rs70936
yes
How does the assembly come out? Are there screws holding it in or plastic tabs or what?
Old 02-01-2013 | 07:09 PM
HKSpeed's Avatar
https://www.scionlife.com/forums/tc-tech-diy-1818/led-swap-cubby-hole-automatic-shifter-45975/
Old 02-01-2013 | 11:21 PM
minhpho's Avatar
sweet!! thanks a bunch!!
RY_TC07
07-18-2017 06:18 PM
rrtxdrvr
05-22-2015 04:58 AM
JMorrill92
03-30-2015 07:05 PM
scsteven
01-25-2015 02:06 AM
Itsdchz
06-30-2009 05:54 AM
