VSS wire location?
VSS wire location?
I have the Pioneer AVIC Z2 but I'm trying to find that speed wire in the tC to hook it up to the pink/white wire on the Z2.. this one here:
http://yuphost.com/images/IMG_2412.JPG
I saw the wiring diamgrams but none are for the 2008.. and I couldn't even find the wire by looking at the 07 diagram.
ok, i hope this helps-
this is for 2006-
It is a purple wire coming off of the ECM which is behind the glove box.
2nd plug from the top.
Also, it is on the radio harness, which is a yellow wire.
this is for 2006-
for the 2008 you can only get it at the ecm behind the glove box like shizzon said. If you have a digital multimeter you can set it to AC voltage and have someone read it off to you as you accelerate. The voltage should increase with speed.
the 2008 diagram pretty much matches with the '07's...
just grab the yellow wire that's right there in one of the stock radio harnesses. (the one that also has the steering control and aux wires.)
im doing a z2 install and its all hooked up except that damn VSS wire. ive her so many different pots on where to get it. my glovebox is out and h have the wire taped to my ECM untill its done
i have an 08 tC. im gonna say 2nd plug from top purple? i need a new meter grrrrr
and since i believe in hard soildering over t-taps, id like to only have to do this once
SkillFreeJake
Scion tC 2G Aero & Exterior
07-27-2015 12:34 AM
randode
44
06-29-2004 04:19 PM
bettysman
02-08-2004 04:50 PM
