Whats the difference in between an 8-ohm sub and a 4-ohm sub
Does n e one know what the difference is in between an 8-ohm sub and a 4-ohm sub... i think it means more power or like it sounds better or somethin... but im not sure....
It depends solely on what amp you're going to use... it also depends on what voice coil configuration youre getting (dual or single)....
Your amp (or the amp you're looking to buy) will be rated at a certain impedance (resistance/ohms) for a particular power output... generally an amp that is rated 500x1 @ 4ohms will put out around 250x1 @ 8ohms because that 8ohm is more resistance to electrical current
Deltafan909
Photography & Video
07-04-2015 04:25 PM
halosinfire
Scion tC 2G Forced Induction
06-10-2015 05:21 PM
CONCRETETC
02-09-2015 08:05 PM
