Who has 2 0 awg GROUNDS in their tC?
:raises hand:
First off...new toy. Tsunami Yellow Top Battery Topper:
I'll be making a custom brushed-aluminum tie down.
From there we follow the ground wire back along the firewall:
In through the grommet on the passenger side(thanks JLTD):
Into my FUSED Tsunami 1 0awg to 2 0awg distro...they're out of the non-fused one right now and I needed something. 250amp ANL fuses are my friend:
And running down the side of the car:
Now, yes, I realize I have power running right next to speaker wire...but it's really the only way I can do it right now. I've listened for a while...there is no added noise. Plus, in theory, when you ground through your car, the entire car is technically the ground wire anyway
Back to making the dish fit.
just out of curiousity... what's the point of running 1 0awg wire into 2 0awg wires? i mean... u can only draw so much power before the first line (before the split) will fail.
Once you ground it to the car, it's running through the entire car anyway.
Also...my hatch is glassed shut
Running it straight to the battery is the same, except I don't need to find a good enough place for a ground stock.
Plus, saying I have 4 0 awg runs in the car is awesome.
alrighty then...
http://home.comcast.net/~TheDesperFamily/10.jpg
the bolt right behind the yellow part of the dipstick, is that where I have the alternator---> battery + connection?
the other connections i know where to run, im just confused about the alternator one :D
yo i got that set up, love the topper, its dope. i have everything grounded to the chassis though. is there a real good reason to run it back to the battery? you gonna set up the gm posts too?
Chassis ground is as good as 4 awg
so theres no reason to distribut the power through the chassis? (im not to good with physics) for some reason, theres something i remember hearing about having to have the power go through the chassis before its returned to the battery. im probly just trippn. set me strait if i am.
just curious, why'd you fuse your ground?
Not really going to hurt anything...would just super ____ me off if one blew.
just a thought, wouldnt the size of the fuse (in mm not ampreres) somewhat be selfdefeating, because the fuses arent as large as the 0 awg wire. if you want an actual ground dist block (one thats all nickle) instead of a power dist block (one with fuse links) i get metra & tsunami stuff really cheap. check out http://tsunamionline.com/product.php?id=730
I'd actually prefer their new Marine grade Lok-Nut one. I'll get it once I get the new pricing
07tcscion
10-08-2015 05:42 PM
