ZENESIS ALARM
Old 09-03-2008 | 01:38 AM
JNasty's Avatar
Default ZENESIS ALARM
hey i just got my zenesis alarm in the mail today and planning on installing it tomorrow.
ive searched and found bits and pieces of info that was helpful
but was wondering if someone can tell me everything i need to know about the install
and no im not doing it myself but want to be more knowledgeable about it thanks guys
manual tc by the way
Old 09-03-2008 | 01:48 AM
mattieg's Avatar
What would you like to know?
Old 09-03-2008 | 01:56 AM
JNasty's Avatar
about the bypassing
the key being chipped
and any other little problems that i can run into
Old 09-03-2008 | 01:58 AM
Carlanga's Avatar
i think I paid about $120 bucks, the only things I can think of right now is to make sure to hook up the alarm in a way that when it goes off the hazard lights will come on and not the low beam headlights. Not good if u have hid's, maybe to the high beams though.
Some shops might not want to take the chance to install the turbo timer/remote start part cuz it's manual. Print the alarm manual and explain them the part that explains that u can program the car to only start under certain configuration, if when u turn off the car it is not on that configuration the car won't start..
Just a heads up I still wouldn't recommend the remote start, bad bad past experience on my other car... TWICE.
Good luck man, you'll love it especially the combo key pad
Old 09-03-2008 | 02:04 AM
JNasty's Avatar
thanks more info guys
Old 09-03-2008 | 02:13 AM
mattieg's Avatar
Well i believe the Zenisis is made for remote starting. If that is the case you will park the car, put your foot on the brake, pull up the e-brake and then let your foot of the brake and press the remote start button twice. I know that was confusing but it makes sure that your car is in neutral every time before you can remote start it. The new viper 5701 works like this. And if you car alarm goes off or if it senses your door trigger then you will need to repeat the previous sequence.
The chip in the key is solved by purchasing a XK05 module that stores the chip information in a little box. It also ties to the stock security system in the vehicle, door triggers, locks and much more. So there is no need to put a spare key inside your car.
You should have no problems if the shop is willing to do the install. Many will guarantee their work for life.
Do you have any more questions I can help you out with?
Old 09-03-2008 | 02:24 AM
JNasty's Avatar
so if i dont have that then i would need to keep a spare key in the car at all times to remote start it?
Old 09-03-2008 | 02:30 AM
JNasty's Avatar
and on a normal install i thought the parking lights are what flashes?
if its my low beams theirs gonna be a problem
Old 09-03-2008 | 02:37 AM
mattieg's Avatar
No dont worry about the parking lights. Usually its parking lights that flash. Its not a big deal changing them around, you just change the resistance value in the wire.
And yes the older modules would require a spare key put inside whats called a 556UW. This then has a wire that goes around the key cylinder. When you activate the remote start the wire sends a signal to the key cylinder and the car thinks the key is in the ignition.
Old 09-03-2008 | 06:07 PM
JNasty's Avatar
does anyone know if this module will work ok with the tc without using a key
and is this all im going to need o be able to use all the features on this alarm
http://item.express.ebay.com/Consume...mdZExpressItem
Old 09-03-2008 | 06:14 PM
hawgs74's Avatar
Call Code alarm and ask them. I use the DEI one mentioned above and have not have any problems with it.
Old 09-03-2008 | 07:33 PM
mattieg's Avatar
ya the xk05 module like i said does not need a key in the vehicle.
Old 09-06-2008 | 06:55 AM
cmv138's Avatar
there is a optional part to get if you want to auto unlock when you get near the car? if so then whats the part #?
cant seem to figure out how to set my knock knock sensor either.
Old 09-07-2008 | 01:32 AM
emsmith2323's Avatar
i really cant help with this
Geedavell
Scion xD ICE & Interior
09-28-2015 02:33 AM
user9430961
09-15-2015 04:16 AM
Armystrong
08-31-2015 09:19 PM
wejarrell
10
08-05-2015 10:19 PM
