bolts on wheels = broken
muteki super tuner lugs.
bought them at autobac's,
had them for about a week, felt a vibration in my steering, went to check it out at my frends hous. finds that 2 lugs/bolts broke off.
looks like imma go to autobac's and complain and have them pay for a new sent of bolts for all 4 wheels? damage 1 means damage to all 4? god dam, everyone with TC's are having bad things happen to them (2nd incident)
the lugs screwed on by hand for about 2 turns, then after that it became RELALY hard to turn. i didnt know that it means "beware, might not fit" i jus thought that it was special and hard to unscrew so people wont steal your rims.
I knew this would be a problem, with all of the companies out there selling locking lugs for our car without the proper seat, etc. I had the same problem when I went to purchase locking lugs. I was sent the wrong ones, that didnt include the washer that the stock lugs had. You need to buy ones that match the stock lugs PERFECTLY. Luckily for you the wrong lugs resulted in some broken bolts instead of something major like a bad accident. The lugs you need look like this
Make sure you get the washer on them, it seats the pressure properly on the rim as intended by the manufacturer.
Re: bolts on wheels = broken
Originally Posted by JasonH
The McGaurds will stop a thief with a lug wrench, but if somebody really wants your wheels they can get them off. Apparently those "Gator Grip" sockets work pretty well.
^ that is what came with my car... those damn allens.. REPLACE THEM.. they broke on my car, it stripped and it just tore to shreds, and i still had to pull it offf and it scratched the lug nut hole... they suck.. i went and got the gorillas.. now those are nice.. my second set, i had them on my old car and sold the car
Originally Posted by MaxxxSpeed
That is why I used this style lug nut and lock:
no those locks do have a different spline key for each set. There are like 10 different variations I believe, and I have regular hollow hex lugs for my others. Plus there arent many options when you need a tuner size lug. Sure there are more options if you have stock rims. I have had real bad experience with regular spline drive tuner locks, the hollow centered ones are much better.
I bought the scion wheel locks but lost the key. Since i had to take off my wheel immediately, my dad took a bigger socket and hammered it into the lock and unscrewed it in less than a minute.
If they really wanted to steal your wheel that bad, all they'd have to do is spend a few bucks on sockets that can't be used anymore.
well its ok now
the problem was they gave me the wrong size. the nuts were to small and wasnt complete fastened. and since they werent completely fastened, the vibration from drive caused it to break.
now autobacs is replace all the lug nuts and all the studs.
so if any of you ever wanna buy parts from autobac's you shoud. :D
Originally Posted by engifineer
The worse part is that I have found that most of the locking lugs out there are CCCRRRRAAAAPPPP! Soft and easy to destroy. I have had good luck with McGaurd, which I heard produces the ones that Scion sells for the tC. Anyone know if this is true?
Originally Posted by burn6010
Set of Gorilla mag seat lugs for toyotas will run you about 20 dollars at discount tire. Put them on my tC the day after I got it.
You are looking for a 12x1.5 sized lugnut.
In my past experiences, any locks under 20 bucks are junk ( as well as ANY part sold by autozone, so dont buy them there either!). I had two different sets in the past that were around 20 bucks and did not last more than taking the wheel off twice. The first ones tore up while putting them on the first time! And I had not even torqued them down yet. They are made out of super soft metal, and the indention for the key would start tearing up right away. It caused the key not to fit, so I had to hammer a 12 point socket over it to get it off. I finally started buying nothing but McGaurd. The last set of them I got (before the tC) cost about $40, but are practically indestructable! Used them for 3 years on a mustang with no issues. The engine started falling apart first..... its a ford or course!! Anyway, IMO McGauard makes a very good quality product, and an extra 20 -30 bucks is worth knowing that you can take your wheel off when needed, or that the lug wont break!
