Check Engine light codes
i bought a code reader because the check engine light is on.
i got two codes
p0441 (p0441 P) = EVAP Emission Control System Purge Flow Fault
p0455 (P0455 P) = EVAP Emission Control Sysem Leak (Large)
does anyone know what these mean and if the dealer will fix them for free?
i have a 2006 scion tc, extended warranty expires in a few months.
thanks
i got two codes
thanks
check out my old thread.
https://www.scionlife.com/forums/sho...d.php?t=196724
Most likely you need a new OEM gas cap but i would first try to unscrew your old one then put it back on and see if the codes clear.
I got those 2 codes a while back found out it was my gas cap. So i tightened it and they went away. About 6-9 months later i got the codes again and tried to repeat the fix, but the codes never went away. I took the car in for service and had them check it out. they said it was the gas tank pipe that was faulty and needed to be replaced. I was quoted 480 bucks and I promptly asked them to give me my car back. I found out that there was a TSB (don't remember the number) for the faulty gas tank pipe and it would have been free to fix if it was still under warranty.
I just bought a scanguage and reset the code. I do get the code intermittently but I just reset them all the time.
I think I'm actually going to buy a new gas tank cap and see if that fixes it.
daniinpitt
04-04-2015 09:07 PM
rcflyer15
12-05-2014 06:15 PM
