Computer Codes
Old 10-28-2010 | 05:23 PM
puertoricaninnh's Avatar
Cool Computer Codes
Can someone please tell me how to repair my car? 06 scion tc.. I keep getting these codes : PO441 and PO455
Thanks
Old 10-28-2010 | 06:30 PM
SquallLHeart's Avatar
have you done anything recent to the car?
intake stuff? check your hoses...
and tighten your gas cap until it clicks a couple of times.
Old 10-28-2010 | 06:48 PM
Spicy_McHaggiz's Avatar
Google and SEARCHING are your friends.
Old 10-28-2010 | 08:41 PM
JahJosef's Avatar
Most likely a vacuum leak or faulty gas cap/not screwed on properly.
Edit: there could be a hairline crack in the gas tank filler neck or return line/seal.
Old 10-28-2010 | 09:28 PM
N0AuTHoRiTy's Avatar
P0441 - Evaporative Emission Control System Purge Flow
p0455 - Evaporative Emission Control System Leak Detected (Gross Leak)
Possible causes:
1)Defective or loose fuel cap
2)EVAP canister or hose cracked
3)Purge or vent solenoid defective
4)Vacuum in EVAP system
Old 11-07-2010 | 05:57 AM
MichaelPBOK's Avatar
9 times out of 10 when a yota comes into the shop and throws that code its gas cap. Either it wasn't on tight or the gasket can be damaged. Other then that it's most likely a fitting on your canister or the canister itself is cracked.
Blunderbuss
10-08-2015 05:56 PM
That_Kid_Ju
09-30-2015 11:05 PM
wayneside
Regional - Southeast
09-23-2015 11:42 AM
wayneside
Regional - Pacific Northwest
09-23-2015 11:29 AM
Quick Reply: Computer Codes
