Disconnect battery - electrical weirdness
Old 08-10-2004 | 04:21 PM
erc's Avatar
erc
Default Disconnect battery - electrical weirdness
So, it turns out when I got my tank filled yesterday, the attendant didn't put the gas cap back on all the way, and it triggered my check engine light.. but th elight didn't go out when I replaced the gas cap, so I disconnected the battery, and re-connected it a few minutes later.
CEL is gone, and hasn't come back, but now I have some other stuff going on.
1. My moon roof controls don't work.
2. I can't roll down my passenger side window with the driver side button (yes, I checked the window lock button) but the passenger side button can roll down the window no problem.
3. The one touch Auto-up/down window feature doesn't work on the passenger side at all.
There may be other things that I haven't noticed yet.
I called my dealership, and they said that clearing the code by disconnecting the battery is a bad idea, and that stuff will need to be re-programmed so that everything works again.
WTF is up with that? So if I disconnect my battery while installing stereo equipment, I'm going to have to take it back to the dealership to have crap re-programmed? Considering my dealership is 3+ hours away, this is something that doesn't really sound appealing to me.
Is there another explanation that I could be missing?
Has anyone else experienced this?
Old 08-10-2004 | 04:24 PM
tC56's Avatar
I have never heard of that. I know that the OBD-II computers do some weird stuff after you disconnect the battery for awhile, but that seems really weird. I wonder how you would reprogram that stuff? That sound like a load of BS but I don't know.
Old 08-10-2004 | 04:25 PM
JasonH's Avatar
You have to reset the windows and roof.
For the doors, from the switch on each door, roll the window down half way then roll it all the way up and keep the button held for a few seconds.
For the roof, I believe I just held the button forward for a few seconds and that did the trick.
Old 08-10-2004 | 04:30 PM
erc's Avatar
erc
Up up, down down, left right, left right, B, A, Select Start...
Sorry, flashback to old Nintendo days
Just out of curiosity, where did you find that out? I'm going to try it on my lunch break.
Old 08-10-2004 | 04:31 PM
Slide's Avatar
https://www.scionlife.com/forums/vie...t=auto+stopped
Read this post. It seems fixable on your own.
Old 08-10-2004 | 04:34 PM
erc's Avatar
erc
Thanks for the link
Old 08-10-2004 | 05:04 PM
xbgeezer's Avatar
Shouldn't this be included in the tech forum for future reference? Anybody know how to do this or is the administrator the only person authorized to make this change?
Old 08-10-2004 | 05:50 PM
erc's Avatar
erc
I really apprecate the info, it worked like a charm. You guys saved me a wasted vacation day from work and a 7 hour round trip to the dealership.
I would say that this should be in the tech forum. I can't believe it's not in the owners manual... (and if it is, I didn't find it)
Old 08-10-2004 | 05:52 PM
JasonH's Avatar
I believe it is in the manual.
Old 08-10-2004 | 06:17 PM
Lakhesis's Avatar
Default Re: Disconnect battery - electrical weirdness
Had this problem with my Corolla a few weeks ago, but in my case the problem was a bad valve in the fuel system. The light won't go out immediately when you replace the cap - just make sure it's on tight and then drive it around for a bit. The system runs periodic tests on itself (at what point during operation, I'm not sure) and after the test clears the light will go off by itself.
Old 08-10-2004 | 06:29 PM
Kev_the_rev's Avatar
erc... you should be able to bring your car to any toyota dealership and have the warranted work be done.. cause i bought my tC at a place 1hr from my house. Now i just get work done on it at the one down ths treet
Old 08-17-2004 | 09:48 PM
aneis's Avatar
RTFM!!
Old 08-17-2004 | 10:07 PM
GeminiTwin's Avatar
Originally Posted by aneis
RTFM!!
Read The F'ing Manual??? Why not just write it out :? .
Old 08-17-2004 | 11:07 PM
Forevermore's Avatar
That ones broke get a new one
drgonzo92
14
04-24-2019 08:27 PM
prescottn
10-08-2015 06:31 PM
gqdabien
09-17-2015 10:23 PM
gottoaster
09-06-2015 08:17 PM
Marialzga
07-31-2015 06:38 PM
