driving with emergency break engaged
depending on how high the handle was, i've droven like 3 miles with it 1 click up and i was like why the heck is my car laggin it until i saw when i was already at my destination LOL. but really no you shouldn't and you should double check it that it's fully down everytime you hop in.
I driven my old Ford Probe with the full brake. Doing speeds of 35 about five-six miles. That was interesting. Got home and my brake pads were smoking
Funny thing about that was I bought the car within a week.
Did the same with my old xA. For some strange reason, the car seemed to disengaged it for me. No struggle on acceleration and no brake pressure. No smoking or burning smell.
Now, I'm used to putting on brake and I'm 100% with turning it off. Helps when you live on a hill and you have better car to take care of, I guess
Well, we actually have a drum brake behind the disc brake for the emergency. So you can't really tell by just looking at the pads. I think I was doing like 3 clicks up, and after I noticed it, I drove for a litte longer and then pulled over to look. It was REALLY hot and I smell something burnt.
However I did try to see if the hand brake still feels right by going up a hill, settig it in Neutral, pull the hand brake, and it feels ok. Also I set it in drive, let it roll, and slowly pull the hand brake click by click. First and second click there was little resistance, third click slowed the car down, and 4th and 5th stopped the car. So that part is normal. What concerns me is that at the 3rd click, while the car is still rolling slowly, there's a high pitch squeal, which then disappears as I pull it to 4th or release it. Does this sound normal?
The only concern I could see would be a warped rotor due to the heat. After it cools, put the car in reverse and back up a ways, use the e-brake to stop the car to set the pads. Not sure if this will work because I am going off the knowledge that older vehicles with drum rear brakes used to have an auto-adjuster that would seat the shoes every time you would apply the brakes in reverse.
I did it ALOT in my old tC. I am not sure why but when I first got it I kept forgetting to lower it 100% and I only noticed when I looked at my dash and seen the light.
Eventually it didn't lock the wheels at full engagement but it still held the car in place on a hill, so effit.
The squeek i'm sure is nothing new and (while I can't explain why it does it) you probably only notice it now because you're looking for it. Don't lose sleep over it, but if you're feeling froggy take off your rear wheel, caliper and rotor and take a peak.
Well, I am no expert when it comes to cars, that's why I am asking. I apologize if I misused words, but hey, at least it got my point through!
But your inputs has been very helpful, I don't feel as bad now.
Emergency has been a popular term for the parking brake for like decades now, haha. Don't feel bad. I actually call it an e-brake also.
Think about it, your main brakes go out, what do you do? Steer for grass, houses, pedestrians? I think not. Hitting a person will dent my hood or worse, so i'm slowing myself with the E-BRAKE.
Am I right or am I right?
Strictly Scionized
Originally Posted by Spicy_McHaggiz
No such thing as an emergency brake, its a parking brake and should never be used for emergency situations
Hmm maybe having no brakes....the EMERGENCY brake will come in handy to slow the car down a little bit.
By the way, airplanes that have hydraulic controls have a cable system as a fail-safe, similar to the "E-brake" in your car.
One afternoon (I had my old Sunfire that I got rid of for my tC), I was supposed to be going to pick my sister up from work. I noticed I had a turn signal light out, so I went ot stop at the auto parts store to get a new turn signal bulb.
Now, the intersection at the bottom of the hill where the auto parts store is VERY busy. I went to stop at the bottom of the hill (waiting to make a right hand turn, while the cars coming the opposite way making a left had the right of way, so I had to yeild/stop). Only problem was, I was hitting the brake, and I wasn't stopping. My foot pressed on the brake pedal and went "THOOMPH" (or something like that)... no stoppage!
So, I pulled on the emergency brake and stopped. I had an emergency, and it stopped me. Scariest thing that ever happened to me.
Had I not noticed my turn signal light was out and stopped at the auto parts store (had to stop using the e-brake at 30mph), I would have went straight to pick my sister up from work, on the highway, at 70mph. The exit ramps around here are VERY short, and I highly doubt the e-brake/parking brake would have stopped me in time from hitting something very dangerous at 70mph. I think someone was looking out for me that day.
So the term e-brake is fine with me (btw, the inspection station missed the fact my brake line was about ready to burst, bubbled up and all... it ruptured, caused me to lose the fluid, and caused my brakes to fail)
To the OP, if you're worried about it, I'd have it looked at just to make sure it's in working order. If you had an emergency and your brakes don't work..........
evolving_machine
10-21-2023 01:16 PM
wiltonhall
01-28-2015 03:46 PM
