Factory Sound Deadening, what kind?
Re: Factory Sound Deadening, what kind?
Originally Posted by eugovector
What kind of sound deadening does the tC come with? Is it just a foam mat, a spray, or a sheet adhesive like Dynamat?
http://www.freewebs.com/johnrussell99/lowvibra.pdf
or brown bread...;) stuff is much cheaper and works just as well...
http://www.b-quiet.com/
just saying since my friend bought this and it worked well... and dynamat extreme is just so expensive
I've used hi-temp mastic adhesive-backed damping sheets before and they worked well. It looks just like dynamat but is less expensive.
http://www.mcmaster.com/
excellent, thank you.
So it looks like the tC dampening consists of strategically placed foam dampeners.
Some Dynamat Extreme should help greatly.
TC has a ton of sound supression items.
Aside from the foam, any cloth makes a halfway decent barrier. There is also the styrofoam under the trunk floor that will supress some noise.
The worst problem I noticed in the car was tire howl. However, I test drove a car with 18s on it and the TRD exhaust. Even with all of that, it was quieter then my DSM which has a whole role of Brown Bread (like dynomat) inside it.
If your really serious, look for a foam solution that will absorb noise, not just reflect it.
cid_mcdp
01-05-2015 02:45 PM
