Gas Octane makes a difference?
I would like to hear some opinions on how the octane changes the preformance in our cars.
My experience is that using lower gas, promotes lower performance. I had a full tank of 93 and everything was perfect. Today i decided to change my gas to 87(it was only the 3rd fill up). Anyways, after i filled it up and started the car, these are the things i noticed. The car is more shakey at idle, and the engine doesnt "purr" as loud as idle and going. The acceleration seems slower and shifting seems smoother. Pros and cons here and there. Is it just me or octane really does make a big difference?
Thanks Im a noob. Sorry for noob question
Makes no difference in quarter-mile times at the dragstrip. The differences you are feeling might be due to different levels of detergents in the fuel, or just the cleanliness of the fuel. A high-quality low octane is the way to go.
thats a lie. yes it does help your time. it also keeps your engine healthier and prolongs the life of your engine. why do you think at some drag strips they have special octane fuel that is a little over 100 octane?
dont EVER go low octane if you want to baby your car.
Scion Corps
DeepSouth Scions
higher octane actually robs your MPG, b/c it causes more combustion. our engines are designed to run off low octane fuel and doing anything other than that is harmful to the engine b/c it was not made to run off that fuel. The only people that should probably use higher octane is people running turbo or a supercharger b/c it needs the higher combustion.
if you dont believe me call your toyota dealer and ask them. there is nothing in it for them to lie about it.
as far as better shifts and quality of gas, that might have something to do w/ where the gas was on the truck when the delivered it. gas from the top is usually the best, also make are you getting gas from the same place? some places add extra chemicals to try to improve the quality
well then i guess i can continue using my high octane.
but its your car do with it as you want. thats the number one rule of cars.
Why did you ask.......?
Re: Gas Octane makes a difference?
Originally Posted by PunkInDrublic
Different posters... look at the names...
https://www.scionlife.com/forums/viewtopic.php?t=43337
heh and no you said that turbocharged cars need higher octane so i said alright then its still good for me to stick with my higher octane.
and thanks glad to know you got my back lol
It's more the quality of the gasoline than the octane... Assuming you're putting the correct octane in your car. For instance, you shouldn't try running 87 octane in a car that requires 91.
thats a lie. yes it does help your time. it also keeps your engine healthier and prolongs the life of your engine. why do you think at some drag strips they have special octane fuel that is a little over 100 octane? dont EVER go low octane if you want to baby your car.
