Headlight Removal
Headlight Removal
Hey people, was thinking of getting hella projectors in my headlights with xenon, any idea how to remove the headlight assemblies? Does it require removing the front bumper... if someone's done this please link me with pics, or some info. Thanks!
I don't get what you need to remove your entire headlight housing unless you were replacing it with projectors or something. If that's the case, I don't know.
But if you're simply wiring the Hella ballest, you really don't have anything to take out. Just pop the hood, look down all the way to the left or to the right, and you'll see the headlight to remove. Twist counterclock wise and pull out carefully. Take care of the wiring and you're all set.
There was this site that I found on projection installs on this CRX. The site had lots of info. It was always down though.
If I remember, preheat the over to 300-350
Once preheated turn it off. Put a bakeing sheet down and a damp towel on the bakeing sheet.
MAKE SURE OVEN IS OFF!!!!!
Place the headlight in the over for about 8-10min. Of course keep an eye on the headlights.
Once time is up use a screw driver of something like that to pry the headlight cover/assembly apart.
If it doesnt come apart or you dont notice the glue doing anything. Put them back in for another 8-10min. Ive done this to my Silvia headlights, so it does work.
Originally Posted by RockstEdy
Check this thread out: UPDATE: going to clear corners any tips
There's even pics
There's even pics
carid
04-07-2015 03:21 PM
