how fast at 1st gear?
I think he is talking about top speed @ redline in first gear. I have no clue so I cant help but my current automatic corsica can do 45mph in first. So for a tC with a 5spd I would say maybe 35-45 range.
Edit: If you have checked that it goes to 28mph, then I take it you own a tC. So why not just take it down your street in first gear then? Im not sure if to many tC owners out there really want to redline first gear just to give you a answer.
i dont mean redline it... i mean hit it to 6500 rpm...
i know an s2000 hit 40mph in first gear tho.... then like 60 on 2nd gear (3rd gear i forgot)
im sure it hits about 30-35mph.
im just askin because for racing situations... once you hit 30mph, shift
people complain that i cant race. i actually ont wanna rev my engine up or hit near redline...
but really when i race i hit between 5000-6000 rpm each gear.... and this is the tC im talkin about
I can see. Thats some what why there is a tach. If you dont want to take the time to look down look into getting a cheap shift light. Maybe even like a little buzzer that will make noise when you should shift. With out driving the car & knowing how the gears are set I would need to test it out. Looking at the specs on scion.com with peak HP @ 5700rpm & TQ @ 4000rpm. With that info I would say shift right around the peak HP number so when you take the next gear it drops you right near your peak TQ so it can pull you on through to the next gear. Just my guess & suggestions though.
yea at high rpms like 5-6 then shift the engine roars louder in the middle of your shifting.... its like rrreeeeeee..... REAAA!!! rreeeee.... REAA!!!! rrreeee.... haha i like that sound..
i wonder how S/C would sound.. i know turbo got that air blow like ____ sound when you shift it goes ____! now that sound is the ____...
i got question. is it just my var or everytime you wobbing it side by side on neutral you hear a clicking sound? or i move it to the right and the click sound just clicks? all the manual cars ive driven on dont click like that. even my friends ask whats that clicking sound.
does anyones tC stick shift does that too???
Re: how fast at 1st gear?
Originally Posted by Diluvium
anyone know how fast the tC reach up at 1st gear? i hit 28mph on first gear once with A/C on tho... i keep forgeting to check how fast it would go. anyone know?
Car & Driver shows the speeds in each gear...
You can use math to figure out speeds in any gear at any rpm.
DRIVETRAIN Transmission: 5-speed manual
Final-drive ratio: 4.24:1
Gear, Ratio, Mph/1000 rpm, Max test speed
I, 3.54, 4.7, 29 mph (6200 rpm)
II, 2.05, 8.2, 51 mph (6200 rpm)
III, 1.33, 12.6, 78 mph (6200 rpm)
IV, 0.97, 17.2, 107 mph (6200 rpm)
V, 0.78, 21.6, 127 mph (5900 rpm)
~3700rpm @ 80mph in 5th gear.
1st gear is very low. I haven't tried it, but I think starting out in second gear would be no problem at all.
Why are some of you so afraid to go up to your redline? You have a rev-limiter which was installed specifically so you don't put your engine into RPM ranges it can't handle. In the Honda's I've raced, I'd bounce it off the limiter one or twice (There's not much time inbetween) and then shift, using up every last bit of power in that gear.
I do know that many Honda's keep making power all the way up to the limiter. with C's, however, I'm not sure what the power curve looks like. Yes, it may make sense to shift before you hit the limiter if power delivery slopes off, but don't be afraid of the rev-limiter.
Thanks for that info. In most cases they do say start out in second. I read some where that you should only use first when towing things or starting out on hills but any other time just start out in second. Now I think this only flys with 4 & 5 spd manuals though. I think the old 3 on the tree ratios would have been a little wide to get started in 2nd.
Back to the original topic. The person who said 29 mph was right. It never ceases to amaze me that people will believe their own anectdotal evidence over simple math. It doesn't make a bit of difference how fast your old Ford Ranger went in first gear. Good Lord.
yea the tC got alot of torque, i think you could get off on 4th gear too.. but the car is gonna start rumbling. you wont stall out tho.
yea i hit 28mph on 1st gear, but the A/C was on. that should make a difference right?
data of tC
1st gear at 5k rpm 25mph approx
2nd gear at 5k rpm 43mph approx
3rd gear at 5k rpm 65mph approx
4th gear at 5k rpm 85mph approx
5th gear at 5k rpm 106mph approx
2nd gear at red line 6200 at 65mph approx
3rd gear at red line 6200 at 86mph approx
will that help any?
will that help any?
yea thats about right, 28-29 mph on 1st gear when i hit 30 that tacho limiter starts jumping it back.
2nd gear up to 51
im not so sure on the seconds tho.....
i just did this 5 minutes ago haha
