I think I dented my rim. =\
I was out driving last night and as I came around a curve I heard a huge thud. Looked back and there was a large rock in the road. I think I might have dented my front left rim. =\
Anyone know how much an OEM rim costs? I know there are some dealers on here, maybe they can help me out.
Thanks
Thanks
just dont replace it ... let the tire wear out till its time for you to change it. then get an aftermarket rims and tires... thats what im going to do with mine. Still trying to avoid getting my rims scratched so i can sell it.
Re: I think I dented my rim. =\
Thanks
Thanks
Kevin
You should be able to tell if it's dented. First off, you should feel a vibration through your steering wheel. That doesn't necessarily mean you dented the rim, it could just be an alignment or balance problem. If you have a vibration, try rotating your tires. While you're at it, inspect the lip of the rim you suspect and see if there's a dent or any damage to the tire. If there's a bulge in the sidewall, you should probably have it replaced. If you see no damage, put your front wheels on the rear and see if the vibration goes away or lessens. You might want to have your suspect wheel inspected as well. It might need to be rebalanced (if a weight flew off or something.)
If you have no problems while driving, and feel no vibrations, and a visual inspection turns up nothing, everything is probably ok.
Put the lil donut spare on. Then buy 3 more to match. That would be a unique ride.
Yeah, but he can afford to go to DNA Lounge every Saturday night for the entire semester. $20 cover plus drinks. He had took five saturdays off and studied instead he'd have tires AND a passing grade.
Priorities...
airmankevin1
11-17-2015 05:44 AM
