If stock pipes were mandrel bent instead of crimped ---
--- would we get better power? I understand that bigger pipes give more flow out of the engine through the exhaust but, wouldn't we get some performance gain from mandrel/smoother bent stock piping instead of the crimp(?) bends that are from the factory? And wouldn't better flowing mandrel bent stock piping produce a gain (probably slight, but still a gain :D ) and not alot of noise?
Would this be easy for a custom shop to produce? Not too expensive?
Just wondering because aftermarket always seems to produce more sound (not necessarily bad) but for me, just looking for better performance not fastest, is a better goal.
Mandrel Bent Pipe
A custom shop can do this, but at that point you might as well get a bigger pipe. Many shops may not stock the 1.75" pipe.
If it is the noise of performance exhaust you are worried about, many shops can install silencers for you that will make it fairly quiet without giving up all of the performance gains.
Re: Mandrel Bent Pipe
Thanks!
So, mandrel bends aren't enough to help?
Silencers are in the end pipe, or can they be put in all along the piping? I've heard there is something called a resonator where is this in relation to the silencer and does it do the same thing? There is a mean throbbing kind of hum sound that comes out from high revving that I notice every now and then, more in the cabin than outside...
Is your cat-back mandrel bent and did it fit with the stock header or is the cat-back pipe bigger than the stock header?
Could a shop just mandrel bend the stock pipe that is already there? I'm mostly asking for a possible project I might try...still in the planning stages.
Al.Truistic
aB
Al.Truistic
aB
I would say for some gains, sense I take it your not going to want to red line each gear to fill it, go for a 2" System. If its possible run it from the manifold back.
http://www.justmagnaflow.com/Catalyt...ters/53000.htm (New Cat #CARK 53064)
http://www.justmagnaflow.com/Univers...Aluminized.htm (Round muffler aka resenator just look for 2" in/out not sure how long you can fit under there.)
http://www.justmagnaflow.com/Univers...Aluminized.htm (The muffler.)
If all this is set up right & all you should get some more power along with a nice sound but nothing that is to loud.
there is a place in bakersfiled or victorville can do mandrel bent piping, but i don't remember the cost. cars at the factory come with small piping. using slightly bigger pipping along with them being mandrel bent will free up some horsepower.
Mandrel Bending
You cannot bend the existing pipe as it has already been crimped. Smooth corners on the inside are what give you the performance hit.
My Cat Back is Mandrel Bent, and was installed just behind the Oxygen sensor. There is a transition from 1.75" to 2.25" with a clamp. I had my guy cut and weld everything. Unless you plan to install a header, just do the Cat Back. There is not enough length between the exhaust manifold and Cat to worry about.
The resonator goes between the Cat and Muffler as a means of tuning the tone of the exhaust. Thinks of it as the "Exhasut Note", as in a musical scale. A Silencer gets installed at the muffler end as a way of controling the Volume of the Exhaust Note. Sound Volume as apposed to area volume/flow.
Keep in mind that anything you add to the system other than a large straight pipe is going to cause some restriction. Your ECU will adjust to whatever you decide.
Originally Posted by Stylis
remeber Al, that bigger pipes means more noise. And I remember when you were wonering about the noise levels on the hills of frisco too. More flow means more noise in our cars, just becareful. :D
Can you explain what a dual pass muffler is? Thanks!
Al.Truistic
aB
Al.Truistic
aB
Originally Posted by fireballfish
Bigger pipe DOES NOT mean more noise necessarily. I could go up to a 2.5" pipe, and put 2 or 3 resonators and a dual pass muffler and be QUIETER than stock.
Guest
Posts: n/a
Thats not relevant to what I was saying, I was implying that using the stock set-up with bigger pipe may cause more noise. I didn't say you could not quiet it down, please read the post before you answer. here we go again.
And yes I want to hear your definition of a "dual pass muffler" please.
Do they make a polished stainless steel stock/1.75 inch auto axle with my tip Gabe :?:
Al.Truistic
aB
Bigger pipe DOES NOT mean more noise nessessarily. I could go up to a 2.5" pipe, and put 2 or 3 resonators and a dual pass muffler and be QUIETER than stock.
ok lets look at what you said, " I am going to add bigger pipe to my scion but before the muffler I am going to add 2 to 3 resinators."
Al.Truistic
aB
Stylis
Is the GURU of Scion Exhaust! Just order up whatever he tells you to order up. If you are near him, take your car to his shop. You could have purchased a whole new exhaust by now if your time is worth anything!
No worries, I know of the Stylis and PrecisionMuffler mystique and the legend that is Scion Central.
So, Stylis what is a dual pass muffler and is a mandrel bent replacement stock system just too outrageously expensive to even consider?
Al.Truistic
aB
Al.Truistic
aB
Al.Truistic
aB
Al.Truistic
aB
Guest
Posts: n/a
Al.Truistic
aB
Al.Truistic
aB
Thanks Stylis again for the great exhaust.
I have to say an exhaust really is one of the nicer things anyone can do to thier ride to raise the style of it. And there is none better than PrecisionMuffler and Gabe's service (---and stories!) to get the job done.
This post is all about getting a discussion going and maybe some info flowing on what and if a mandrel bent stock exhaust system is something to be looked into. I'm thinking it is not the worst thing you can do and regardless of 1.75 or 2.25 inch size pipe better flow is better flow.
Congrats on the recent win Gabe!
Al.Truistic
aB
Thanks fireballfish! Much appreciated. The quest (or at least the questions) continue... Kitsap is in Washington State, no? I used to have a girlfriend a long time ago from Gig Harbor, WA...
Al.Truistic
aB
Al.Truistic
aB
actually I sold al truistic an axle back and he asked for a different tip already, I bet kit sappy exhaust is not going to install a tip that you want. I take care of scionlife people and answer all of their questions, besides I don't make a cat back system to sell, maganflow has the best catback over everyone. I sell axle backs and manifold back systems(dyno tested) The manifold back system is 500.00 and will beat out any cat back ever made. But you wouldn't know anything about that would you. Hope your satisfied with the cat back
Al.Truistic
aB
I've seen Kitsap muffler sell complete catbacks for about $400. For my money I'm going to get one from a company who's used a dyno to design theirs... If I were you since you don't want the additional sound, I would stick with your stock system. If you want a cooler looking tip, have one welded (or bolted ) in. most of the performance exhaust systems are louder, and only make maybe 5 HP near redline. If you get the K&N intake, you get a dyno proven 8hp... you will get more noise from your engine bay, but less than a performance exhaust would add
I know I'd really like to see a dyno "shoot out" for the 2nz-fe.
from what I've seen dyno wise Gabe's manifold back coupled to a performance intake will give you just around or over 8 horsepower to the wheels... and don't mind his sniping, he's had to deal with quite a few lately..
that's crazy about your car crossing country...
