Lucas oil products
Lucas oil products
Hey all, haven't been around much - been busy with other things in life. Anyway, I have a quick question for everyone - what does everyone think of lucas oil products? Specifically the fuel injector cleaner. My car has around 11k on it right now and I would like to add this to clean out the system. Thoughts, suggestions, comments?
Thanks!
Thanks!
Originally Posted by smokeydog001
IF IT'S THE SAME COMPANY THAT USE TO MAKE ELECTRICAL PARTS FOR BRITISH CARS, I WOULDN'T EVEN POUR IT DOWN A SEWER DRAIN!
Re: Lucas oil products
Thanks!
Thanks!
I know I sound like a commercial all the time but 44k is all that has ever worked, I tried most everything else out there. www.bgprod.com to find a dealer near you. One can cost me about $18-19, but worth it.
I have used Lucas synthetic oil stabilizer (with synthetic oil) and fuel injector cleaner every oil change since my car was new and I currently have 115k with no problems. i think they make great products but that just from experiance Everyone has an opinion
Lucas makes ddecent products, not sure where everyone got the idea they are that bad.
However, the only fuel system cleaner I ever use is BG44k like mentioned above. Very good stuff. Also one of the only ones I have actually seen do much of anything. Its also what Toyota dealers typically use.
However, you dont need to run anything through it at 11k. I run cleaner through my cars at about every 40k - 50k.
I also run zero additives in my oil.
http://www.bobistheoilguy.com/images/lucas/lucas.htm
The reason why I would rather not try out Lucas on my car.
http://lubecontrol.com/lube.htm
Lube Control has been recommended to me by many of my friends though.
Hmmm, well I have been using Lucas Oil (Synthetic) with Castrol Synthetic Oil and a bottle of their Injection cleaner every oil change for years on all the cars I used to own... Never had any problems with it... Currently I'm using a 50/50 mixture in my cousins 97' Neon with 130k miles on it and it runs like a champ...
I have seen that exact same demo done, except the lucas climbed the gears just like it was supposed to
But again, I dont run additives in my oil. Good oil changed regularly is all you need
lucas makes great stuff
I used the trans stuff in my chevy with almost 300k and a slipping tranny.
It fixed it the slipping almost instantly and the truck kept running about a year after that.Its still running now with almost 400k
I used the oil in the crank case and noitced a differance in gas millage ( in the chevy not in my tc nothing has been used in the tc)
ScionLife Editor
11-20-2014 05:20 PM
