My rant about a light........
Anyone seen this yet? I didn’t even know the car had one but…..
I was at work and my wife was driving the tC. She called and said “A light with a funny looking light just came on, what does it mean?” The car only had 1500 miles on it so I just figured the dealer forgot to add motor oil. No big deal, right? I’ll just get a new car, right? SO I tell her it’s fine, and to not worry about it(she still worried).
A few more minutes pass and she says the car feels funny and is pulling to the right- I scream “Pull over now, the tire is flat and you’re going to ruin it if you don’t pull over now”
Wife- “But I’m on the freeway”
Me- “pull over to the side right now”
Wife- “I’m just gunna drive to the next exit”
Me- “crap”
So I drive up there in my IS, and try to put my full size spare from the IS on the scion, but the bolt patterns are not the same. I curse at Mr. Toyota for ruining my day
I put the bright yellow doughnut spare that we are cursed with on the scion and drive it to my buddy, who conveniently manages a tire shop
He laughs at the Bridgestone, as it is FUBAR
He then laughs because his shop does not have Bridgestone
I tell him to take the Bridgestone from my IS Full size spare and put it on the Scion…..Turns out Mr. Toyota not only uses multiple bolt patterns, but also uses different patterns of rubber. I again curse at him.
I now have an off brand of tire on my car…..the stock Bridgestone is $200+ from a different shop- I can buy a full set of non-Bridgestone tires for less than one Bridgestone. I again curse at Mr. Toyota for using a retardedly expensive tire.
I drove to vegas last weekend and the light came on again. I am driving so I pull over right away with the wife yelling at me to go to the next exit. I have no flat, so read the manual and it says that the low pressure sensor can sense when the tires do not match, and will cause the light to come on. Once again, I yell obscenities at Mr. Toyota
So now I have a funny looking light on at all times until I can find time to go to the dealer to see if they can do anything.
Should I pay Mr. Toyota a visit?
Me- “crap”
Just get new tires and sell those, if you can afford it.
$155 Bridgestone Potenza Stock (1)
$70 Continental Conti-Extreme Contact (Perf. All Season) (1)
Had the conti's on the all-trac, so beautiful. Much better tire than the potenza's.
Originally Posted by KYBoy
did you try to hit the reset button in the glove box?
The first time i ignored the light the car started beeping, but it's gotten over that phase
If the dealer can't do anything I'm gunna get all new tires-
try www.tirerack.com i fund some nice kuhmos for the tc for 109 each they also have BFgoodwrench for 97 each... look around on the site i found some for my xb for 35 each
I'm confused.
So a big warning light went off on the car and instead of having her pull over or get off the freeway you told her to forget about it and keep driving? And you're bent that toyota uses 5x100 for the tC and 5x114 for the IS300? Then you tried to swap tires and they were *gasp* different tires!? Then you were mad that the treads on the tires were different so instead of just using it you bought ANOTHER different tire?!?!
Sweet jeebus.
Sweet jeebus.
you can't have 2 diffrent tires on the car, it will set the light off
either have bridgestone or contis not both
put it in the key on position and then hold the tire pressure button till it goes away keep holding it till it flashes 3 times
it will recalibrate after you drive it about an hour or so
the light will come on in any of these cases
-tire rotation
-balance
-mounting
-adjusting tire pressure
-tire rotation
-balance
-mounting
cherryBox
13
03-20-2006 04:49 PM
DisneybB
33
02-20-2005 09:34 PM
