Is my tc weird? Shifting and RPM Question.
MY cousin drove a lot of stick shift cars, maybe about 30 or so.. and I let him drive my 07 tc, but he told me that something is wrong with my transmission. He told me that whenever he presses the clutch that my rpm is way too high and takes forever to drop down. I noticed it as well but I have never driven another car before so I was just wondering if it was jsut the tc's that are like that or is it supposed to drop fast when i press the clutch? it really takes a long time for the rpm to drop.. and even when i'm in neutral the rpm doesn't drop right away.
If I'm not mistaken, it should idle at about 700rpm. As far as your clutch is concerned, your rpm should go right back to idle when you take you foot off of the clutch. Unless your shifting into another gear, but that's another story. Yes, the rpm should go right back to idle like you were just revving your engine.
This isn't necessarily a transmission problem. Infact, I don't think it's your tranny at all. I think if it were, then your car would stall right after starting it. I don't know what it is for sure though. I would have it checked out. It could be just as simple as your accellerator pedal not communicating with your ecu. That might be why your engine isn't returning to idle as quickly as it should. But it could be more complicated then that. I'm not sure. Have it checked out asap. You don't want to be driving and not be able to shift into neutral and brake.!
Originally Posted by engifineer
He hasnt driven that many stick shifts then. They all vary in this respect. It is the rotational mass of the internals and flywheel. There is nothing wrong with the car.
there is already a thread about this, there is nothing wrong with your scion, it was designed this way to help beginers (and camry drivers) shift smoother, here is the link
https://www.scionlife.com/forums/vie...695&highlight=
It's fine, as has been mentioned. Also, he's probably sticking on the throttle longer than necessary... the throttles on our tC's are not only sensitive, but also different than other throttles, sorta.
It takes a little getting used to... that's it, though, nothing wrong
Originally Posted by WeaponX6X
I wonder if it has to do with the electronic throttle at all?
I don't see why it's such a big deal? It's not like you're gonna shift faster than it takes the rpms to drop to idle....atleast I can't...
Yes, as a beginner, I think having the engine speed hang around is good b/c it will give time for them to learn to release the clutch properly. I dont find it smooth b/c I tend engage the clutch 500 above the proper RPM..... so the engine always has to drop its speed, and if I let out the clutch just a bit too quickly, it will have a slight tug. Compared to if the RPMs drop and I engage the clutch right when the engine and transmission speeds are proper, then I can let out the clutch faster without any jerkness..... hence why ppl match rev.
Heavy stock flywheels make the engine maintain momemtum longer between shifts. They allow you to shift more leisurely between each gear without the rpms getting too low. Try driving your car like you're not in a hurry, and you'll see how easy it is to shift.
If you don't like the way it works stock, then get a lightweight flywheel. Revs will rise and fall much more quickly.
