Octane Booster.........
Old 07-11-2004, 02:42 PM
Raziemlutto1's Avatar
Default Octane Booster.........
Anyone Used this products before??? octane boosters, do they improve anything at all?? any difference
Raziemlutto1 is offline
Old 07-11-2004, 05:47 PM
scionspecialistvegas's Avatar
They work pretty good, they work better for for getting moisture out your fuel system. Airplane (Av-gas) is what really works good for racing. But unless your car is spark knocking,pinging, I wouldn't worry about it. I have tried premium and midgrade and notice no difference in power or economy, I know someone will say else wise. If my full size pick up that is a different matter. premium all the way, for that pig. Premium makes big difference in how she runs. Bill
scionspecialistvegas is offline
Old 07-11-2004, 06:54 PM
TheScionicMan's Avatar
They help in cars that need higher octane. The scion is designed for lower octane, it won't really help or make it go faster...
TheScionicMan is offline
Old 07-11-2004, 06:56 PM
its_ikon's Avatar
i would just save your money. yo will not notice much of anything with it. the car puts out 108 crank hp.
its_ikon is offline
Old 07-12-2004, 07:53 AM
Guest
Guest
Posts: n/a
You will run too lean and predetonate.
Old 07-12-2004, 03:08 PM
Sciomodr's Avatar
Absolutely no need to run higher octane fuel in this or any engine that is not set up to take advantage of the higher octane rating (ignition timing/compression/forced induction). An entire book could be (and has) been written on this topic.
Call me if you really want an earful on the thread, I started posting three times before I gave up. Its really quite difficult to put into a paragraph post.
Mike
Sciomodr is offline
Old 07-12-2004, 09:08 PM
Scioco's Avatar
_edit_
Scioco is offline
Old 07-12-2004, 09:19 PM
greenbox's Avatar
dont use any booster or fuel cleaner in the tank. i have gotten a few cars at work with melted fuel pumps. the denso fuel pumps rubber diaphram melts because those additives are too strong.
greenbox is offline
Old 07-12-2004, 11:13 PM
jolyrgr's Avatar
jolyrgr is offline
Old 07-13-2004, 05:14 AM
Guest
Guest
Posts: n/a
I thought it would, cause its higher octane the gas would burn faster causing you to run lean. Too high octane and boom... So its not a possibility?
Old 07-13-2004, 06:25 AM
Team Sushi
djct_watt's Avatar
I don't remember if it is pre-detonation or late detonation, knock or ping. . . forgot, but I also heard this from a reputable source.
My best friend's father worked(retired) for Shell (he refuses to fill at Shell hahaha) and said that it isn't unheard of, although rare, that you get one of those effects if you use high octane in a car designed for low octane, but this was more common when computers weren't as advanced and could compensate for the change in octane like modern cars can. One thing is for sure, there is absolutely no gain, and is a definite LOSS in performance. Motortrend, Car and Driver, or Road and Track (forgot which one) did a test on this about 3 years back, and showed a consistent loss in performance and fuel economy when you use premium in a car designed for low octane. . . now if you have major mods this might be different.
djct_watt is offline
Old 07-13-2004, 08:45 AM
w0mbatizlle's Avatar
you will pre detonate if you are running lean, higher octane fuel burns faster therfore if your fuel system and your computer are not set up for this you will pre detonate. so instead of rolling your eyes and saying um no why dont you try posting something useful instead of being a child.
w0mbatizlle is offline
Old 07-13-2004, 05:22 PM
empleh's Avatar
if you're gonna be driving in extremely hot weather, putting higher octane gas (like 89-92) might be a good idea, because in really hot weather the onboard computer will retard the engine to make it run with 87 octane fuel. but, still, the diff is gonna be minor. maybe on the trip from cali to vegas.
empleh is offline
Old 07-13-2004, 05:29 PM
UnFocused's Avatar
those octane boosters that claim " adds 4 points"- That really means .04 points. My pops thought he could get regualr and add that stuff to get premium- umm NO!!
UnFocused is offline
Old 07-13-2004, 06:26 PM
yeah if you only mix one bottle, but if you mix it to get a higher octane is what im talking about
Old 07-13-2004, 08:47 PM
CleanZX3's Avatar
LOL!!
Thats not how it works at all. The higher the octane number, the slower the fuel burns. Try reading around.
The octane rating of gasoline tells you how much the fuel can be compressed before it spontaneously ignites. When gas ignites by compression rather than because of the spark from the spark plug, it causes knocking in the engine. Knocking can damage an engine, so it is not something you want to have happening. Lower-octane gas (like "regular" 87-octane gasoline) can handle the least amount of compression before igniting.
The compression ratio of your engine determines the octane rating of the gas you must use in the car. One way to increase the horsepower of an engine of a given displacement is to increase its compression ratio. So a "high-performance engine" has a higher compression ratio and requires higher-octane fuel. The advantage of a high compression ratio is that it gives your engine a higher horsepower rating for a given engine weight -- that is what makes the engine "high performance." The disadvantage is that the gasoline for your engine costs more.
The name "octane" comes from the following fact: When you take crude oil and "crack" it in a refinery, you end up getting hydrocarbon chains of different lengths. These different chain lengths can then be separated from each other and blended to form different fuels. For example, you may have heard of methane, propane and butane. All three of them are hydrocarbons. Methane has just a single carbon atom. Propane has three carbon atoms chained together. Butane has four carbon atoms chained together. Pentane has five, hexane has six, heptane has seven and octane has eight carbons chained together.
It turns out that heptane handles compression very poorly. Compress it just a little and it ignites spontaneously. Octane handles compression very well -- you can compress it a lot and nothing happens. Eighty-seven-octane gasoline is gasoline that contains 87-percent octane and 13-percent heptane (or some other combination of fuels that has the same performance of the 87/13 combination of octane/heptane). It spontaneously ignites at a given compression level, and can only be used in engines that do not exceed that compression ratio.
During WWI, it was discovered that you can add a chemical called tetraethyl lead to gasoline and significantly improve its octane rating. Cheaper grades of gasoline could be made usable by adding this chemical. This led to the widespread use of "ethyl" or "leaded" gasoline. Unfortunately, the side effects of adding lead to gasoline are:
Lead clogs a catalytic converter and renders it inoperable within minutes.
The Earth became covered in a thin layer of lead, and lead is toxic to many living things (including humans).
When lead was banned, gasoline got more expensive because refineries could not boost the octane ratings of cheaper grades any more. Airplanes are still allowed to use leaded gasoline, and octane ratings of 115 are commonly used in super-high-performance piston airplane engines (jet engines burn kerosene, by the way).
CleanZX3 is offline
Old 07-13-2004, 09:00 PM
scottmbritton's Avatar
Originally Posted by CleanZX3
The octane rating of gasoline tells you how much the fuel ... "snip"
Thank you for that. That was a good read.
scottmbritton is offline
Old 07-13-2004, 09:55 PM
jolyrgr's Avatar
This was useful?
nice post clean. If I had typed that instead of the , I'd have been here for an hour.
jolyrgr is offline
Old 07-15-2004, 05:03 PM
Scioco's Avatar
_edit_
Scioco is offline
Old 07-15-2004, 05:35 PM
TokyoRaver's Avatar
Wonder what would happen if you filled up the entire tank with octane booster? maybe with a 1/2 gallon of gas.
TokyoRaver is offline
Quick Reply: Octane Booster.........
