oil and milage and burning
Old 09-10-2006 | 10:18 PM
trialsindude's Avatar
Strictly Scionized
Default oil and milage and burning
I have 54,000 miles on my 05 tC, been changing oil with mobil1 ever since 10,000 miles. Question is for those that change their own oil how much are you able to drain back out during your next oil change? I notice my car has been drinking oil like its nobody business. I change my oil every 5K, last time I change my oil it lost a quart. I didn't get a change to change my oil yet but I need to but I notice on the oil dip stick its at half now, which means I lost approx 2 quarts. But I also drive the car hard too. I know cars eat oil but I didn't know it drinks it! Just wondering if anyone else notice.
Old 09-10-2006 | 10:33 PM
farberio's Avatar
Every car is a little different. 1 qt in 5000 miles ive heard before.
If it makes you feel any better rotarys go through 1 qt in 3000 miles.
Old 09-10-2006 | 11:41 PM
brian's Avatar
mine doesn't burn any at all from what i can tell, but i use conventional oil. my car has about 25k miles and i change it every 5k.
Old 09-11-2006 | 12:03 AM
Tcguy85's Avatar
if it's 2 quarts low, don't wait to add oil. 2 quarts low means you only have 2 quarts in it right now so add some right away.
Old 09-11-2006 | 01:26 AM
ESEMRFOZZ13's Avatar
have you checked under your car for any oil drips, also take out and check your spark plugs to determin how they're burning. do you drive like an a$$, mis shifting, popping clutches at every light and jerking the car.
Old 09-12-2006 | 01:57 AM
TKE_BH964's Avatar
Have you changed your drain plug washer lately?
I have 46k on my car, and I had been noticing the same thing. It seems to have stopped when I changed out the washer last time I changed the oil.
Old 09-15-2006 | 03:32 AM
Strictly Scionized
yeah i change the drain plug washer every time i change the oil, its only like 70 cents for one, when i pick up the toyota oil filter i get the washer at the same time.
I guess its just the constant beating on the car thats why. I know hondas usually eat a lot of oil if you go into vtec a lot.
Old 09-15-2006 | 05:13 PM
blakerwry's Avatar
Typically the difference between the full and low mark on the dip stick is 1 quart. So if you are halfway between the two you are probably only half a quart low.
When you change the oil and filter do you re-measure the oil after driving for a day?
BlingSlade
09-05-2015 09:52 AM
antayala
09-04-2015 06:12 PM
Forced4
08-21-2015 10:22 PM
Ways808
08-02-2015 09:13 PM
